ANSI PBP Keyboard Mapping for Tilde character
(01-15-2020, 03:43 AM)bcnaz Wrote:
(01-14-2020, 08:27 PM)appdev46 Wrote: I noticed the tilde character is not mapped correctly.  Also I noticed the double quotes and at symbol are swapped.
Can this be mapped somewhere to be corrected or is it in the ANSI keyboard firmware?
   This is actually a software problem.
If you go into your 'keyboard menu'
You will find it says  EU keyboard.  You need to add US keyboard.
Then  Delete the EU keyboard,  that should resolve your problem.
I had the same issue.  My  @  key and  " keys were reversed.
 That fixed my problem.  Thank you so much!!!
RE: ANSI PBP Keyboard Mapping for Tilde character - by appdev46 - 01-15-2020, 05:25 AM
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,805 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 702 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,111 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,679 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,462 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,330 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,837 08-09-2021, 09:20 PM
  Some keyboard keys not working oddsocks 10 10,776 04-20-2021, 08:33 AM
Last Post: dsimic
  Spare parts / keyboard mbreese 2 4,212 01-07-2021, 07:40 AM
Last Post: dsimic
  How easy is it to add donor keyboard and trackpad? ENV 3 5,126 11-12-2020, 07:51 AM
Last Post: Kaythe
