(almost) upstream uboot/atf
i strongly advise against using this with the mrfixit debian. that debian kernel is built to work with firmware that works differently in important ways, using upstream firmware may not work at all. that said, the article was written assuming an aarch64 host (manjaro). the mrfixit debian is, i think, a 32 bit userland, so even there you'd have to cross-compile for aarch64. i have absolutely no clue how debian names its cross-compiler packages though.
cloning does work fine here, even though it takes a while and the progress output for http clones really isn't great Sad will have to do something about that eventually ...
(almost) upstream uboot/atf - by User 15997 - 01-11-2020, 04:21 PM
RE: (almost) upstream uboot/atf - by Arwen - 01-11-2020, 11:30 PM
RE: (almost) upstream uboot/atf - by Gazoche - 01-12-2020, 08:49 PM
RE: (almost) upstream uboot/atf - by Arwen - 01-12-2020, 11:48 PM
RE: (almost) upstream uboot/atf - by Luke - 01-13-2020, 05:43 AM
RE: (almost) upstream uboot/atf - by danielt - 01-13-2020, 05:25 AM
RE: (almost) upstream uboot/atf - by belfastraven - 01-14-2020, 02:12 PM
RE: (almost) upstream uboot/atf - by User 15997 - 01-14-2020, 02:44 PM
RE: (almost) upstream uboot/atf - by as400 - 01-15-2020, 04:12 PM
RE: (almost) upstream uboot/atf - by User 15997 - 01-15-2020, 08:31 PM
RE: (almost) upstream uboot/atf - by as400 - 01-16-2020, 07:07 AM
RE: (almost) upstream uboot/atf - by User 15997 - 01-16-2020, 07:18 AM
RE: (almost) upstream uboot/atf - by as400 - 01-16-2020, 07:37 AM
RE: (almost) upstream uboot/atf - by User 15997 - 02-04-2020, 08:09 AM
RE: (almost) upstream uboot/atf - by clover - 02-04-2020, 11:34 AM
RE: (almost) upstream uboot/atf - by User 15997 - 02-04-2020, 11:43 AM
RE: (almost) upstream uboot/atf - by User 15997 - 02-06-2020, 07:33 PM
RE: (almost) upstream uboot/atf - by as400 - 02-07-2020, 01:48 AM
RE: (almost) upstream uboot/atf - by Natrox - 02-07-2020, 09:25 AM
RE: (almost) upstream uboot/atf - by clover - 02-07-2020, 11:34 AM
RE: (almost) upstream uboot/atf - by Natrox - 02-07-2020, 07:45 PM
RE: (almost) upstream uboot/atf - by User 15997 - 02-07-2020, 02:32 PM
RE: (almost) upstream uboot/atf - by clover - 02-07-2020, 08:33 PM
RE: (almost) upstream uboot/atf - by Natrox - 02-07-2020, 10:14 PM
RE: (almost) upstream uboot/atf - by clover - 02-08-2020, 12:14 PM
RE: (almost) upstream uboot/atf - by Natrox - 02-08-2020, 10:18 PM
  How to rewrite uboot to emmc pineitup 5 8,815 12-27-2020, 10:35 AM
Last Post: nightranger73
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 53,530 07-28-2020, 03:18 PM
Last Post: SamWilts
Exclamation Flash dhivael's SPI uboot (risky) clover 51 52,973 06-20-2020, 03:24 PM
Last Post: craftkiller
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,585 06-07-2020, 02:37 AM
Last Post: as400
