Hibernate Manjaro -> NetworkManager doesn't start anymore
today I pushed the button to hibernate the system but it didn' t wake up again. So I pushed the power button to restart the notebook.
Now sytemd can't start NetworkManager.service. There is a core-dump.
Is ist possible to make NetworkManager work again?
[~]> systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
    Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service>
   Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
            └─NetworkManager-ovs.conf
    Active: failed (Result: core-dump) since Sat 2020-01-11 18:15:>
      Docs: man:NetworkManager(8)
   Process: 835 ExecStart=/usr/bin/NetworkManager --no-daemon (cod>
  Main PID: 835 (code=dumped, signal=ILL)
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Scheduled >
Jän 11 18:15:05 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Start requ>
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Failed wit>
Jän 11 18:15:05 b00k systemd[1]: Failed to start Network Manager.
[~]> systemd-analyze critical-chain
The time when unit became active or started is printed after the "@>
The time the unit took to start is printed after the "+" character.
graphical.target @3min 32.222s
└─multi-user.target @3min 32.221s
 └─smb.service @3min 31.895s +324ms
   └─network-online.target @2min 1.625s
     └─network.target @2.906s
       └─NetworkManager.service @6.023s +352ms
         └─dbus.service @2.598s
           └─basic.target @2.588s
             └─sockets.target @2.588s
               └─dbus.socket @2.588s
                 └─sysinit.target @2.586s
                   └─systemd-timesyncd.service @2.222s +363ms
                     └─systemd-tmpfiles-setup.service @2.165s +51ms
                       └─local-fs.target @2.156s
                         └─run-user-1000-gvfs.mount @26.539s
                           └─run-user-1000.mount @22.150s
                             └─local-fs-pre.target @2.156s
                               └─lvm2-monitor.service @637ms +1.14>
                                 └─lvm2-lvmetad.service @717ms
                                   └─systemd-journald.socket @606ms
                                     └─system.slice @328ms
                                       └─-.slice @328ms
[~]> systemd-analyze blame
  2min 57ms systemd-networkd-wait-online.service
1min 30.246s nmb.service
    30.062s NetworkManager-wait-online.service
     3.036s bootsplash-hide-when-booted.service
     1.143s lvm2-monitor.service
      898ms dev-mmcblk2p1.device
      779ms systemd-logind.service
      618ms systemd-random-seed.service
      441ms systemd-udevd.service
      389ms tlp.service
      363ms systemd-timesyncd.service
      353ms systemd-networkd.service
      352ms NetworkManager.service
      324ms smb.service
      297ms systemd-journald.service
      240ms user@1000.service
      239ms polkit.service
      184ms systemd-udev-trigger.service
      138ms systemd-journal-flush.service
       51ms systemd-tmpfiles-setup.service
       39ms dev-hugepages.mount
       39ms systemd-tmpfiles-setup-dev.service
       35ms dev-mqueue.mount
       34ms systemd-modules-load.service
       33ms systemd-remount-fs.service
       32ms sys-kernel-debug.mount
       30ms systemd-sysctl.service
       30ms systemd-rfkill.service
       30ms tmp.mount
       29ms systemd-backlight@backlight:edp-backlight.service
       28ms user-runtime-dir@1000.service
       27ms sys-fs-fuse-connections.mount
       27ms systemd-update-utmp.service
       27ms kmod-static-nodes.service
       26ms systemd-user-sessions.service
Jän 11 18:15:05 b00k systemd[1]: NetworkManager-wait-online.service: Job NetworkManager-wait-online.service/start failed with result 'dependency'.
Jän 11 18:15:05 b00k systemd[1]: Dependency failed for Network Manager Wait Online.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Start request repeated too quickly.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 5.
Jän 11 18:15:04 b00k systemd[1]: systemd-coredump@4-838-0.service: Succeeded.
Jän 11 18:15:04 b00k systemd-coredump[839]: Process 835 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 835:
                                            #0  0x0000aaaae4aa8120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffa21674bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffa219e000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:04 b00k systemd[1]: Started Process Core Dump (PID 838/UID 0).
Jän 11 18:15:04 b00k systemd[1]: Started Network Manager.
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4775] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4726] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4725] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:04 b00k systemd[1]: Started Hide bootsplash after starting the system.
Jän 11 18:15:04 b00k systemd[1]: bootsplash-hide-when-booted.service: Succeeded.
Jän 11 18:15:04 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:04 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 4.
Jän 11 18:15:04 b00k systemd[1]: systemd-coredump@3-828-0.service: Succeeded.
Jän 11 18:15:04 b00k systemd-coredump[829]: Process 825 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 825:
                                            #0  0x0000aaaab078a120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffbdd794bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffbddb0000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:03 b00k systemd[1]: Started Process Core Dump (PID 828/UID 0).
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8540] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:03 b00k systemd[1]: Started Network Manager.
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8492] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8490] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:03 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:03 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 3.
Jän 11 18:15:03 b00k systemd[1]: systemd-coredump@2-819-0.service: Succeeded.
Jän 11 18:15:03 b00k systemd-coredump[820]: Process 816 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 816:
                                            #0  0x0000aaaab3dbf120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffb61844bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffb61bb000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:03 b00k systemd[1]: Started Process Core Dump (PID 819/UID 0).
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0382] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0315] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0313] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:02 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:02 b00k systemd-logind[778]: Watching system buttons on /dev/input/event3 (HAILUCK CO.,LTD USB KEYBOARD System Control)
Jän 11 18:15:02 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 2.
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd[1]: systemd-coredump@1-799-0.service: Succeeded.
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd-coredump[801]: Process 796 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 796:
                                            #0  0x0000aaaadbd66120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffa0e654bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffa0e9c000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:02 b00k systemd-udevd[464]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jän 11 18:15:02 b00k systemd-udevd[464]: Using default interface naming scheme 'v243'.
Hibernate Manjaro -> NetworkManager doesn't start anymore - by Gerhard - 01-11-2020, 12:19 PM
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,747 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,134 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,204 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 884 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,246 08-31-2023, 04:20 PM
Last Post: TRS-80
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,017 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,965 08-21-2023, 09:08 PM
