USB-C charging
can you please give me some information about your power bank.
Including (maybe) some (good) pictures of the PCB.
I need to know if there which/any IC is out there to control USB-C PD and/or USB-2 charge mode
Note these are different modes and need different type of hardware.
Currently PBP will *only* support USB-C PD in online and/or standby mode.
... and no USB-2 charger mode, due missing hardware.
Also there is (slight) error I must investigate
@danielt
Please note:
If you want to buy any USB-C power meters, there are two versions out there.
Buy the bidirectional ones
USB-C charging - by fpex73 - 01-10-2020, 05:24 AM
RE: USB-C charging - by Luke - 01-10-2020, 05:36 AM
RE: USB-C charging - by danielt - 01-10-2020, 05:39 AM
RE: USB-C charging - by fpex73 - 01-10-2020, 06:11 AM
RE: USB-C charging - by ElektromAn - 01-11-2020, 06:32 AM
RE: USB-C charging - by fpex73 - 01-11-2020, 08:05 AM
RE: USB-C charging - by ElektromAn - 01-11-2020, 08:52 AM
RE: USB-C charging - by zaius - 01-11-2020, 02:17 PM
RE: USB-C charging - by fpex73 - 01-11-2020, 08:59 AM
RE: USB-C charging - by fpex73 - 01-14-2020, 04:51 AM
RE: USB-C charging - by ElektromAn - 01-15-2020, 11:38 AM
Photo P{inebook Pro not charging Ome Ko 6 1,965 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,875 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,494 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,269 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,809 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,637 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,830 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,608 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,030 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,116 05-30-2020, 06:05 PM
