Minimal 64bit ARM RootFS for Debian and Ubuntu
(02-13-2016, 09:51 PM)patrickhwood Wrote: I supposed I could have modified uboot's environment or script.bin to change the root= setting in the kernel's args, but that would have entailed mucking around with allwinner's uboot, and I'd prefer to spend my time elsewhere.
I'm using apritzel's image, he found a workaround for loading a custom environment into allwinners u-boot. The mainline kernel lacks of support for USB, WiFi and Ethernet at this time. I assume the android 3.10 kernel supports it, but without the kernel sources (the BSP sources seem to be broken), the 3.10 kernel binary is totally worthless.
(02-13-2016, 07:25 PM)patrickhwood Wrote: Are you using the latest aarch64 rootfs?  SysV init isn't supported out of the box in that -- systemd is the default init system.
I used the latest Archlinux aarch64 rootfs. The Arch people are smart enough to include a compatibility package for systemd.
(02-13-2016, 07:25 PM)patrickhwood Wrote:  Also, ubuntu hasn't used /etc/inittab for quite a while.  i enabled getty on ttyS0 with this script in /etc/init/ttyS0.conf:
You're totally right, this refers to Debian. Ubuntu for aarch64 still has some issues, see here.
RE: Minimal 64bit ARM RootFS for Debian and Ubuntu - by umiddelb - 02-14-2016, 01:23 AM
  Arch, Debian or other for Pinebook? cootcraig 3 9,624 05-01-2019, 09:11 AM
Last Post: cootcraig
  Pine64: Minimal SDL config Max11 3 8,389 01-04-2019, 03:47 PM
Last Post: Max11
  Issues with both Deb and Ubuntu germanshep 0 3,557 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 14,020 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 11,785 03-01-2017, 02:46 PM
Last Post: dkryder
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 22,221 02-03-2017, 05:50 AM
Last Post: pfeerick
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 6,542 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 8,998 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 4,963 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  mounting rootfs Shai 1 4,256 10-01-2016, 07:59 AM
Last Post: waldo
