Looking to commission a new Chromium build (COMMUNITY BOUNTY)
I started by exploring current build from ayufan. I was hoping that it is possible to fix crostini by enabling some kernel flags in /sys/kernel. From source code I found approximate command and arguments to start a container manually from a terminal . Using journalctl to see logs live I found that kernel can't allocate enough memory for vm. So I decided first try to build vanilla chromium os for generic arm board and then try reproduce build from ayufan before making further steps. But laptop I can use for building had not enough memory (only 8 Gb). I already got 8 more Gb memory. But because my laptop is in the office I can make another try only on Monday. Meanwhile I'm reading book about operation systems to get more theoretical knowledge.
RE: Looking to commission a new Chromium build - by obyknovenius - 01-03-2020, 01:16 PM
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,488 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Chromium OS 78? obyknovenius 2 6,015 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,654 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 3,828 11-04-2019, 08:38 AM
