Flashing not working
(02-28-2020, 10:15 PM)cjmakes Wrote:
(02-24-2020, 06:36 AM)wibble Wrote: Are you sure it's the same error? You say you're using the bcm2835spi driver, but the debug output above is for the bitbanging bcm2835gpio driver.
Yes, different driver, same error.
Had you *previously* been using the bcm2835spi driver?
AFAICT bcm2835spi contains a sneaky trick where both the RPi and the nRF52 will be outputting data on the SWDIO pin at the same time (e.g. the RPi pushes 0v whilst the nRF52 pushes 3v3 for some cycles). Without some kind of current limiting resistor inline on the SWDIO line then this sounds a bit risky to me
Flashing not working - by yokonav - 12-28-2019, 06:49 AM
RE: Flashing not working - by yokonav - 01-15-2020, 12:08 AM
RE: Flashing not working - by cjmakes - 02-23-2020, 03:05 AM
RE: Flashing not working - by wibble - 02-24-2020, 06:36 AM
RE: Flashing not working - by cjmakes - 02-28-2020, 10:15 PM
RE: Flashing not working - by danielt - 05-06-2020, 07:31 AM
RE: Flashing not working - by jkl - 05-25-2020, 08:46 AM
RE: Flashing not working - by danielt - 05-26-2020, 04:10 AM
RE: Flashing not working - by jkl - 03-05-2020, 07:50 AM
RE: Flashing not working - by jkl - 03-06-2020, 03:12 AM
RE: Flashing not working - by fld - 03-06-2020, 10:41 AM
RE: Flashing not working - by jkl - 05-05-2020, 11:14 AM
RE: Flashing not working - by slembcke - 03-04-2021, 03:24 PM
RE: Flashing not working - by danielt - 03-11-2021, 04:39 AM
  Flashing chris.burmajster 2 1,394 03-24-2025, 06:18 PM
Last Post: chris.burmajster
  No Luck flashing WaspOS MadHatter 0 1,645 12-11-2023, 01:19 AM
Last Post: MadHatter
  Accelerometer stopped working victor9 15 17,835 02-13-2023, 05:05 PM
Last Post: Luri
  Screen stopped working properly pcfreak9000 3 3,814 01-18-2023, 04:28 PM
  PineTime Touch Screen Stopped Working BlunderingBushcraft 3 4,833 07-30-2022, 04:19 PM
Last Post: headgr
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,279 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 13,489 04-28-2022, 04:27 AM
Last Post: ITCactus
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 4,450 04-11-2022, 05:03 AM
Last Post: ITCactus
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 2,790 03-28-2022, 08:22 PM
Last Post: danimations
Sad Account not working - missing permissions? Droidian 0 2,175 09-24-2021, 05:30 AM
Last Post: Droidian
