Flashing not working
(03-05-2020, 07:50 AM)jkl Wrote: I was using an Adafruit Feather nRF52 to develop our custom firmware for the PINETIME (as it has the exact same chip, but also serial, LEDs and so on). I also had the same behaviour with this board and the bcm2835spi driver. It worked for a day and a half (continuously connected) and after I power resetted it it stopped working. I'm getting the same error as @cjmakes . The firmware I flashed on the chip as when it worked the last time is still working so I don't think the chip itself is broken. But I think it could have to do something with the nRF52832. If anyone here has a solution I'd really like to know it.
I thought a bit more about the circumstances when the issue happened first. And if I remember correctly I had a small electrostatic discharge shortly before the problem arose. I didn't think much about it because the firmware continued working as intended. Did anyone of you had something similar happen? I think it would be unusual for a discharge to result in such a specific problem (I would have expected the device to be just broken and not turning on again). But I just want to make sure this wasn't the reason.
Flashing not working - by yokonav - 12-28-2019, 06:49 AM
RE: Flashing not working - by yokonav - 01-15-2020, 12:08 AM
RE: Flashing not working - by cjmakes - 02-23-2020, 03:05 AM
RE: Flashing not working - by wibble - 02-24-2020, 06:36 AM
RE: Flashing not working - by cjmakes - 02-28-2020, 10:15 PM
RE: Flashing not working - by danielt - 05-06-2020, 07:31 AM
RE: Flashing not working - by jkl - 05-25-2020, 08:46 AM
RE: Flashing not working - by danielt - 05-26-2020, 04:10 AM
RE: Flashing not working - by jkl - 03-05-2020, 07:50 AM
RE: Flashing not working - by jkl - 03-06-2020, 03:12 AM
RE: Flashing not working - by fld - 03-06-2020, 10:41 AM
RE: Flashing not working - by jkl - 05-05-2020, 11:14 AM
RE: Flashing not working - by slembcke - 03-04-2021, 03:24 PM
RE: Flashing not working - by danielt - 03-11-2021, 04:39 AM
  Flashing chris.burmajster 2 1,394 03-24-2025, 06:18 PM
Last Post: chris.burmajster
  No Luck flashing WaspOS MadHatter 0 1,645 12-11-2023, 01:19 AM
Last Post: MadHatter
  Accelerometer stopped working victor9 15 17,835 02-13-2023, 05:05 PM
Last Post: Luri
  Screen stopped working properly pcfreak9000 3 3,814 01-18-2023, 04:28 PM
  PineTime Touch Screen Stopped Working BlunderingBushcraft 3 4,833 07-30-2022, 04:19 PM
Last Post: headgr
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,279 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 13,489 04-28-2022, 04:27 AM
Last Post: ITCactus
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 4,450 04-11-2022, 05:03 AM
Last Post: ITCactus
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 2,790 03-28-2022, 08:22 PM
Last Post: danimations
Sad Account not working - missing permissions? Droidian 0 2,175 09-24-2021, 05:30 AM
Last Post: Droidian
