Remote Desktop Support?
(05-01-2016, 01:47 PM)Rochambeaux Wrote:
(05-01-2016, 11:10 AM)baryluk Wrote: Oh. It is a commerical product. But it looks a client is open source to some extent. Not sure if the same is true for the server part. You can try, or ask them or check their support channels. It might work, who knows. I guess, they might be doing some strong optimizations, and compression, which might not work properly on the pine64 (i.e. they might be using some assembly or special libraries even), but it is worth a try if you are into it.
If not. I would say, try things like xrdp, or NX.
Yes, Linux do have remote desktop capability since before Linux existed. It is called X11, and was created in 70s or so. You can use it without any problems on Pine too.
I was just trying to give you some info about more modern approaches, that might be better in some aspects, especially when used from Windows machine (setting X11 server on Windows might be a pain for people without much knowledge). And I gave you about 8 different solutions like that. I.e. xrdp and vino.
What's a commercial product? What are you recommending I try?
It means you pay for it Wink
Remote Desktop Support? - by Rochambeaux - 04-30-2016, 09:49 PM
RE: Remote Desktop Support? - by nukedawg - 05-01-2016, 12:00 AM
RE: Remote Desktop Support? - by androsch - 05-01-2016, 12:01 AM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 12:47 AM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 09:48 AM
RE: Remote Desktop Support? - by baryluk - 05-01-2016, 10:25 AM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 11:01 AM
RE: Remote Desktop Support? - by baryluk - 05-01-2016, 11:07 AM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 11:10 AM
RE: Remote Desktop Support? - by baryluk - 05-01-2016, 11:10 AM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 01:47 PM
RE: Remote Desktop Support? - by baryluk - 05-01-2016, 02:54 PM
RE: Remote Desktop Support? - by nomadewolf - 05-01-2016, 03:11 PM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 03:18 PM
RE: Remote Desktop Support? - by baryluk - 05-01-2016, 04:34 PM
RE: Remote Desktop Support? - by Rochambeaux - 05-01-2016, 06:37 PM
RE: Remote Desktop Support? - by rahlquist - 05-01-2016, 09:20 PM
RE: Remote Desktop Support? - by tebori - 06-26-2016, 03:59 PM
RE: Remote Desktop Support? - by tampadave - 10-01-2016, 02:55 PM
RE: Remote Desktop Support? - by HayseedGeek - 10-01-2016, 05:08 PM
  Programming languages support under PINE64 baryluk 6 17,358 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  AXP803 Battery Charger Support xalius 14 32,840 12-22-2017, 08:59 AM
Last Post: Velociraptor
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 38,282 10-07-2017, 10:06 PM
Last Post: speedro86
Wink Pine64 Will support Freenas or openmediavault ? joe 1 6,283 04-13-2017, 07:44 AM
Last Post: xalius
  Possible to get 4K resolution on Linux desktop? tycoonbob 6 15,004 01-12-2017, 01:28 AM
Last Post: swinging
  Pine64 as a viable desktop replacement ? here are my thoughts! Luke 11 23,175 01-06-2017, 04:49 AM
Last Post: dkryder
  Problems with remote printers with pine64 (SOLVED) LocoMJ 2 5,775 12-14-2016, 04:32 PM
Last Post: LocoMJ
  Binfmt_misc support cztian 1 4,910 08-17-2016, 11:49 PM
Last Post: longsleep
Question Joystick/Gamepad support Drakuwa 3 8,231 08-10-2016, 10:12 AM
Last Post: xalius
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 21,589 08-09-2016, 05:59 PM
Last Post: dkryder
