Screws and Spacers
(12-31-2019, 01:55 PM)bcnaz Wrote: As to your opening :  May I suggest you consider using a sliding door rather than a hinged door  ?   just a thought.
or even an overlapping flat cover with 4 screws attaching it at the corners.
The intent would be to not have anything coming through the back of the case.  HInge would be super-glued to botom of case, as would fastener.  Slider could work if a track could be developed.  If I am able to but a case bottom or two,  I can try various options...
Screws and Spacers - by belfastraven - 12-25-2019, 07:29 PM
RE: Screws and Spacers - by tophneal - 12-26-2019, 08:05 AM
RE: Screws and Spacers - by belfastraven - 12-26-2019, 10:59 AM
RE: Screws and Spacers - by zaius - 12-26-2019, 01:50 PM
RE: Screws and Spacers - by billjank - 12-30-2019, 02:49 PM
RE: Screws and Spacers - by bolinches - 12-26-2019, 03:16 PM
RE: Screws and Spacers - by bcnaz - 12-31-2019, 12:32 AM
RE: Screws and Spacers - by belfastraven - 12-31-2019, 01:34 PM
RE: Screws and Spacers - by bcnaz - 12-31-2019, 01:55 PM
RE: Screws and Spacers - by belfastraven - 12-31-2019, 06:41 PM
RE: Screws and Spacers - by bcnaz - 01-01-2020, 12:24 AM
RE: Screws and Spacers - by feoh - 10-13-2020, 09:57 AM
  Screws on bottom case coming loose quadrantids 8 8,442 01-20-2021, 03:47 AM
Last Post: quadrantids
  Missing Screws missingchip 2 4,686 06-06-2020, 04:08 PM
Last Post: missingchip
  Alternative to the screws? MIchael 10 14,523 03-12-2020, 08:46 AM
Last Post: ab1jx
