New NVMe SSD not seen by OSes
(01-24-2020, 08:26 PM)Musse Wrote:
(12-25-2019, 03:58 AM)Arwen Wrote: @tophneal, yes, 80mm are the most common length. Followed by 42mm, then 100mm.
Western Digital does make a M.2 NVMe line that has the same capacities in 30mm, 42mm & 80mm lengths.
These also have published power specifications, (reasonably good), unlike other brands.
https://www.westerndigital.com/products/...-sn520-ssd
Western Digital has another M.2 NMVe line, (only in 80mm lengths though), with good power specifications;
https://www.westerndigital.com/products/...e-nvme-ssd
Hi Arwen!
I tried to upgrade my T440s with this SSD: WD SN520 NVMe 512 GB M.2 2242 PCI Express 3.0 x2. The motherboard do not recognize the SSD at all. It is recognize the SanDisk 64GB with windows 10. I tried to put the brand new WD SSD on an enclosuer and connect to 2 other pcs, and still not detected. I contacted the seller and he says it must works, so is it the quality of the WD SSD or it might be something else?
My opinion is that the SSD does not work, it's broken. If you bought it from a normal retailer, I'd return it and get a replacement.
Otherwise I have no kowlege of those particular WD SN520 SSDs. Those WD SSDs turned up in my NVMe search for devices with published power specifications. I've not yet bought one.
Arwen Evenstar
Princess of Rivendale
New NVMe SSD not seen by OSes - by tophneal - 12-24-2019, 07:41 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-24-2019, 09:23 PM
RE: New NVMe SSD not seen by OSes - by Redbeard - 01-08-2020, 12:18 PM
RE: New NVMe SSD not seen by OSes - by tophneal - 12-24-2019, 10:49 PM
RE: New NVMe SSD not seen by OSes - by bcnaz - 01-26-2020, 12:44 AM
RE: New NVMe SSD not seen by OSes - by tophneal - 01-26-2020, 09:08 AM
RE: New NVMe SSD not seen by OSes - by xmixahlx - 12-24-2019, 11:52 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-25-2019, 03:58 AM
RE: New NVMe SSD not seen by OSes - by Musse - 01-24-2020, 08:26 PM
RE: New NVMe SSD not seen by OSes - by Arwen - 01-25-2020, 05:55 AM
RE: New NVMe SSD not seen by OSes - by as400 - 12-25-2019, 07:22 AM
RE: New NVMe SSD not seen by OSes - by tophneal - 12-25-2019, 08:26 AM
New NVMe SSD not seen by OSes - by tophneal - 12-25-2019, 10:54 AM
RE: New NVMe SSD not seen by OSes - by Arwen - 12-25-2019, 02:22 PM
  New Working nVME gilwood 0 213 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,527 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,808 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,374 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,895 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,854 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,717 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,634 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,786 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,101 02-09-2021, 11:32 PM
Last Post: dsimic
