default os: loop while login as rock
(12-31-2019, 11:51 AM)Jeremiah Cornelius Wrote: < SNIP >
Quote:Anyway this is not that important since you mentioned :
Code: $ sudo mrfixit_update.sh
So I can still update the system as my other user.
thanks again. All the best for 2020!
Regards, Adrian
It's a good idea to add sudo and include your user by group membership to sudoers. If for nothing else but these occasions.
If you want to then change a forgotten root user password, "sudo su -" gets you a root shell with environment, and then a regular "passwd" will change root, without asking for previous shadow entry.
This also helps when you are running things that sudo has difficulty with - such as some scripts. I hate editing these to prepend extra "sudo" commands to lines.
Thanks for your hints.
Adrian
Messages In This Thread |
RE: default os: loop while login as rock - by gritibaenz - 01-02-2020, 01:20 PM
Possibly Related Threads… |
Thread |
Author |
Replies |
Views |
Last Post |
No Sound on Default Manjaro KDE |
carlosqueso |
4 |
5,012 |
04-01-2021, 07:17 AM
Last Post: carlosqueso
Graphical login hanging after password entry |
mhill8 |
2 |
3,275 |
03-29-2021, 08:32 AM
Last Post: jacksonliam341
PBP Went Blank After Login |
iscmob |
2 |
2,917 |
12-07-2020, 09:28 AM
Last Post: iscmob
Pinebook Pro Won't Accept Login |
GFreeman |
16 |
16,135 |
09-03-2020, 11:44 AM
Suspend with NVME not working - Default Debian |
appdev46 |
5 |
8,481 |
07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
Login screen issue. |
LinuXchoicE |
2 |
4,048 |
07-07-2020, 09:06 AM
Last Post: LinuXchoicE
Default OS update log |
Luke |
194 |
273,088 |
06-11-2020, 11:25 PM
Last Post: xmixahlx
OEM Script - Factory Default |
xmark |
0 |
1,856 |
06-07-2020, 06:51 AM
Last Post: xmark
How do you upgrade Chromium on default Debian that came with my PBP |
james64 |
6 |
7,767 |
05-26-2020, 07:21 AM
Last Post: User 6582
Stuck on login screen |
Kscott6969 |
0 |
1,888 |
04-20-2020, 10:58 PM
Last Post: Kscott6969
