Adding the NVME causes boot loop?
(12-17-2019, 02:25 PM)zaius Wrote:
(12-17-2019, 01:44 PM)swulff Wrote: Any idea what a symptom of drawing too much power could be? I don't know much about that side of things but looping in boot seems odd.
That the computer doesn't have enough power to run?  Maybe that's why it won't boot?
My gut tells me zaius has identified the source of your boot loop problem.
I have a USB 3.0 external hardrive that I can attach and use after the PBP has started. But if I plug it into the PBP then start the PBP, then it goes into a boot loop too. The external hard drive draws too much power when starting to allow the PBP to boot properly (even when the PBP is attached to the external power source), I expect the same occurs with your NVMe drive. It is probably drawing too much power while the PBP is trying to boot.
Adding the NVME causes boot loop? - by swulff - 12-14-2019, 01:39 PM
RE: Adding the NVME causes boot loop? - by zaius - 12-16-2019, 11:49 AM
RE: Adding the NVME causes boot loop? - by swulff - 12-17-2019, 01:44 PM
RE: Adding the NVME causes boot loop? - by zaius - 12-17-2019, 02:25 PM
RE: Adding the NVME causes boot loop? - by Arwen - 12-17-2019, 04:50 PM
RE: Adding the NVME causes boot loop? - by hmuller - 12-17-2019, 08:22 PM
RE: Adding the NVME causes boot loop? - by swulff - 12-20-2019, 01:07 PM
RE: Adding the NVME causes boot loop? - by Arwen - 12-20-2019, 08:11 PM
  NVMe drives not detected mattpenn 18 24,702 12-24-2024, 08:54 PM
  NVMe reukiodo 0 1,888 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 3,080 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 4,529 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 4,469 11-28-2022, 12:56 PM
Last Post: dachalife
  unable to boot after manjaro update gega 6 7,296 10-28-2022, 01:18 PM
  NVme intall usage? tkudog 2 5,377 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 3,725 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 4,778 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 9,130 07-09-2021, 08:45 PM
Last Post: moonwalkers
