Enclosure for under $10
I actually gave it a try and it worked rather nicely. I had some trouble cutting the acrylic glass and opted to use a Dremel with diamond blade. That led to the edges being quite rough. I sanded it down a bit though. How did you do it?
I used 2 mm acrylic sheets (3€ for more than enough), M3 threaded wire that I cut down to 4.5 cm pieces for the legs and normal steel nuts.
To drill holes into the acrylic without cracking it I first pinched an indent into it at the correct spots and then used the Dremel again, this time with a needle type diamond tip to first drill through in a smaller diameter. The final 3mm hole I then drilled out using a simple hand drilling tool.
After assembly, I put some heatshrink on the end of each leg.
Thanks for the idea!
Here are some pictures:
[Image: SmLSwkU.jpg]
[Image: kQXNnBc.jpg]
[Image: MEENIbl.jpg]
Enclosure for under $10 - by S.A.RN. - 04-29-2016, 11:51 PM
RE: Enclosure for under $10 - by queonda - 04-30-2016, 02:31 AM
RE: Enclosure for under $10 - by Keex - 05-05-2016, 06:08 AM
RE: Enclosure for under $10 - by Luke - 05-05-2016, 07:22 AM
RE: Enclosure for under $10 - by Keex - 05-21-2016, 02:04 PM
RE: Enclosure for under $10 - by brf - 05-21-2016, 03:56 PM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,730 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 33,965 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,405 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,466 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,665 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 12,892 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,804 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,855 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 18,901 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,568 10-13-2016, 08:47 AM
Last Post: Bluphire
