NVMe SSD adapter installation instructions?
 See thread   ' Pro NVMe adapter Does not fit '
Post number 73 by wizzard,  excellent picture of an SSD installed.
 Notice the spacer that holds the ssd,  this is the piece that hits the touch pad on a full sized ssd on an un-cut adapter board.
  Using the short ssd is a simpler 'fix'
Also note:
There are several other alternate methods, if you look around a bit.
Another, cut the adapter board and held a full sized module in place using a cable tie.
Also it is necessary to attach the module to the adapter board FIRST 'IF' you do use the Spacer to attach the module to the adapter. !
the silver screw goes thru the adapter board into the spacer, the modules seats into the groove of the spacer.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
RE: NVMe SSD adapter installation instructions? - by bcnaz - 12-15-2019, 03:20 PM
  New Working nVME gilwood 0 204 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,505 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,792 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,310 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,876 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,845 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,632 12-10-2021, 07:47 PM
Last Post: josmo
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,382 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 2,612 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,752 07-09-2021, 08:45 PM
Last Post: moonwalkers
