Flashing Updated U-Boot on Android
(01-14-2020, 08:30 AM)tophneal Wrote: I did not, though it should be possible in a few different ways, both I don't have the entire info required to do, though. But it should be possible if using a Linux on SD to write Android to eMMC, if you write a different u-boot after writing the Android image. Alternatively, it should also be possible to the same if writing Android to an SD instead.
I tried this. However, it seems that the updated uboot doesn't work for Android. The active LED goes on shortly and then goes back out after flashing to the eMMC. Any suggestions?
Flashing Updated U-Boot on Android - by tophneal - 12-05-2019, 07:14 AM
RE: Flashing Updated U-Boot on Android - by brent.thierens - 01-15-2020, 11:57 AM
Flashing Updated U-Boot on Android - by tophneal - 01-16-2020, 06:05 AM
  Google on Android? KC9UDX 21 39,762 03-17-2023, 11:35 AM
  No Android build working! pin 60 115,881 07-03-2021, 06:08 PM
Last Post: justiceankomah
  MD5 On Android jaysistar 0 3,680 03-14-2020, 08:38 AM
Last Post: jaysistar
  Arguments for android support metcalsr 20 41,567 02-08-2020, 12:12 PM
Last Post: Idaho
Exclamation All android buillds on wiki for Microsd missing GPT? TDC_PBP 14 28,656 01-31-2020, 11:22 PM
  Any word about Android builds? tophneal 36 66,756 01-26-2020, 12:06 AM
Last Post: Account
