Bricked PBP after writing image to eMMC?
@dazld Here you go:
       Un-TESTED!!!! Use at your own risk. This is from the default Debian, but may
work on others.
       While powered off, switch eMMC to disabled state. Then power on. If the user
is not fast enough with the switch to enabled state, the OS image on the SD card
won't see the eMMC. Thus, it may be needed to un-bind and re-bind the eMMC driver.
Note, it is still REQUIRED to enable the eMMC via the hardware switch. These
instruction below, MAY allow the OS to find it after boot.
       The first 2 outputs may show nothing, which could happen if OS thinks the eMMC
does not exist. The 3rd command checks and sees if it's possible to unbind and bind.
Lines 4 & 5 are the real work. Though again, line 4 may not do anything if the device
is already un-bound.
# blockdev --getsize64 /dev/mmcblk1
125069950976
# readlink /sys/block/mmcblk1
../devices/platform/fe330000.sdhci/mmc_host/mmc1/mmc1:0001/block/mmcblk1
# ls /sys/bus/platform/drivers/sdhci-arasan
bind  fe330000.sdhci  uevent  unbind
# echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
# echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/bind
Arwen Evenstar
Princess of Rivendale
RE: Bricked PBP after writing image to eMMC? - by Arwen - 12-06-2019, 06:22 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,465 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,086 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 390 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,442 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,793 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 855 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,089 10-10-2022, 06:22 AM
Last Post: maxjrh
  6/22 run of PBPs - is reimaging eMMC with new OS possible still? elitegamercody 29 11,305 10-04-2022, 07:55 PM
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 110,624 08-24-2022, 02:06 PM
Last Post: petersen77
