pine64 512MB network unusable
(04-29-2016, 08:05 AM)Manilow Wrote: I  installed the debian image (longsleep 20160421), as that seems to be the only viable option for the 512MB version.
All OS images here are based on longsleep's work and he prepared a simple method to update all these images so they can benefit from latest fixes. I don't understand why this important information is not featured in the download section in the wiki.
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_uboot.sh)
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh)
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh)
Regarding the Ethernet problems. None of the devs that do the real work here experienced these problems so far (only the integer overflow issue affecting the 2GB boards that has been fixed by longsleep within a few days 4 weeks ago). Since you're the first here not only whining but using the right equipment what about putting a pcap trace online so that others are able to look through?
And just a thought: When you install on both machines iperf or iperf3 and then connect Pine64 <--> Pine64+ directly. Do you also get duplicate packets and how does performance look like (+85 Mbits/sec is what should be expected)
pine64 512MB network unusable - by Manilow - 04-29-2016, 08:05 AM
RE: pine64 512MB network unusable - by tkaiser - 04-29-2016, 08:32 AM
RE: pine64 512MB network unusable - by longsleep - 04-29-2016, 11:23 AM
RE: pine64 512MB network unusable - by androsch - 04-29-2016, 04:56 PM
RE: pine64 512MB network unusable - by Manilow - 05-01-2016, 11:33 AM
RE: pine64 512MB network unusable - by tkaiser - 05-01-2016, 11:43 AM
RE: pine64 512MB network unusable - by Manilow - 05-01-2016, 11:57 AM
RE: pine64 512MB network unusable - by tkaiser - 05-01-2016, 12:07 PM
RE: pine64 512MB network unusable - by Manilow - 05-02-2016, 03:40 AM
RE: pine64 512MB network unusable - by Manilow - 05-02-2016, 10:45 AM
RE: pine64 512MB network unusable - by longsleep - 05-02-2016, 10:46 AM
RE: pine64 512MB network unusable - by Manilow - 05-03-2016, 06:43 AM
RE: pine64 512MB network unusable - by tkaiser - 05-03-2016, 07:07 AM
RE: pine64 512MB network unusable - by longsleep - 05-03-2016, 11:14 AM
RE: pine64 512MB network unusable - by Manilow - 05-04-2016, 01:56 AM
RE: pine64 512MB network unusable - by tkaiser - 05-04-2016, 02:09 AM
RE: pine64 512MB network unusable - by Manilow - 05-06-2016, 02:18 AM
  Programming languages support under PINE64 baryluk 6 12,221 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,868 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 24,326 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,014 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 5,929 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 34,978 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,092 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,539 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,625 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 36,934 10-26-2017, 05:51 PM
Last Post: gregjo
