12-01-2019, 08:33 PM
(This post was last modified: 12-01-2019, 08:34 PM by jsfrederick.)
My numbers are just about the same as Evilbunny's, see below.
I am using Armbian Stretch (www.armbian.com) for the Rock64, and PiVPN (www.pivpn.io).
I have a a case that has a fan so it runs pretty cool for me. I got my case from here: https://www.kksb-cases.us/
As TLLIM said, the Rock64 is the same size as the RPi, but i recommend that you get a Rock64 specific case since the connectors are slightly different.
root@pihole:~# openssl speed -evp aes-128-cbc -elapsed
You have chosen to measure elapsed time instead of user CPU time.
Doing aes-128-cbc for 3s on 16 size blocks: 16437665 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 13192876 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 6888083 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 2453359 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 352688 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 16384 size blocks: 175202 aes-128-cbc's in 3.00s
OpenSSL 1.1.0l 10 Sep 2019
built on: reproducible build, date unspecified
options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr)
compiler: gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/usr/lib/ssl\"" -DENGINESDIR="\"/usr/lib/aarch64-linux-gnu/engines-1.1\""
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes
aes-128-cbc 87667.55k 281448.02k 587783.08k 837413.21k 963073.37k 956836.52k
root@pihole:~#
