ROCK64 as VPN Gateway
(12-01-2019, 05:30 AM)evilbunny Wrote:
Rock64:
# openssl speed -evp aes-128-cbc -elapsed
You have chosen to measure elapsed time instead of user CPU time.
Doing aes-128-cbc for 3s on 16 size blocks: 15650249 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 12464649 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 6646786 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 2423452 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 348775 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 16384 size blocks: 175497 aes-128-cbc's in 3.00s
OpenSSL 1.1.1d  10 Sep 2019
built on: Sat Oct 12 19:56:43 2019 UTC
options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr)
compiler: gcc -fPIC -pthread -Wa,--noexecstack -Wall -Wa,--noexecstack -g -O2 -fdebug-prefix-map=/build/openssl-H2OJIf/openssl-1.1.1d=. -fstack-protector-strong -Wformat -Werror=format-security -DOPENSSL_USE_NODELETE -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2
The 'numbers' are in 1000s of bytes per second processed.
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes  16384 bytes
aes-128-cbc      83467.99k   265912.51k   567192.41k   827204.95k   952388.27k   958447.62k
RockPro64:
Doing aes-128-cbc for 3s on 16 size blocks: 66070573 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 40764719 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 14919383 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 4125855 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 545375 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 16384 size blocks: 274066 aes-128-cbc's in 3.00s
aes-128-cbc     352376.39k   869647.34k  1273120.68k  1408291.84k  1489237.33k  1496765.78k
Hi @evilbunny
these numbers look amazing (compared to the PI4). What operating system are you using?
I think that the Rock64 could be the solution for my performance problems... Am I correct that the size of the Rock64 is equal to the size of the RPI4? I have a small Rack for my PIs I would like to mount the Rock64 there.
Thanks!
Bye
ROCK64 as VPN Gateway - by Talkabout - 11-30-2019, 12:48 PM
RE: ROCK64 as VPN Gateway - by jsfrederick - 11-30-2019, 08:16 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-01-2019, 04:59 AM
RE: ROCK64 as VPN Gateway - by evilbunny - 12-01-2019, 05:30 AM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-01-2019, 05:41 AM
RE: ROCK64 as VPN Gateway - by tllim - 12-01-2019, 01:50 PM
RE: ROCK64 as VPN Gateway - by evilbunny - 12-02-2019, 01:35 AM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-01-2019, 04:57 PM
RE: ROCK64 as VPN Gateway - by jsfrederick - 12-01-2019, 08:33 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-02-2019, 04:16 AM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-03-2019, 05:01 AM
RE: ROCK64 as VPN Gateway - by xalius - 12-03-2019, 05:13 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-04-2019, 03:35 AM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-04-2019, 12:13 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-04-2019, 03:26 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-04-2019, 05:13 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-13-2019, 04:46 AM
RE: ROCK64 as VPN Gateway - by Rocklobster - 12-13-2019, 07:50 PM
RE: ROCK64 as VPN Gateway - by Talkabout - 12-14-2019, 03:42 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 114 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,452 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,864 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 255 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,771 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,792 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,399 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,974 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 907 10-07-2022, 07:50 PM
Last Post: rookie_267
