Charging via USB-C
It has become apparent to me that charging via USB-C only works properly (fast) when the PBP is on.
The suspicion is that this has to do with PD negotiation failing when the device is powered off. This results in slow standard USB charging.
The graph below shows the charging pattern with the device on (orange boxes) and off (between the two boxes).
I'll talk to the relevant people and ask about what can be done. In the meantime, if you want your PBP to charge at its optimal using USB-C, make sure that its turned on.
This doesn't affect charging via the barrel jack.
It may be a issue specific to the default Debian MATE or other OSs too - haven't checked. Please report below if you've got experience with other OSs.
[Image: khCuoq0.png]
Charging via USB-C - by Luke - 11-25-2019, 04:54 AM
RE: Charging via USB-C - by ElektromAn - 11-25-2019, 03:07 PM
RE: Charging via USB-C - by danielt - 11-26-2019, 04:05 AM
RE: Charging via USB-C - by danielt - 11-26-2019, 05:17 AM
RE: Charging via USB-C - by zaius - 11-26-2019, 01:10 PM
RE: Charging via USB-C - by Luke - 11-26-2019, 01:16 PM
RE: Charging via USB-C - by danielt - 11-29-2019, 03:15 AM
RE: Charging via USB-C - by hdk - 11-26-2019, 07:47 AM
RE: Charging via USB-C - by Luke - 11-26-2019, 08:17 AM
RE: Charging via USB-C - by ElektromAn - 12-03-2019, 03:26 PM
RE: Charging via USB-C - by andybleaden@gmail.com - 12-15-2019, 09:46 AM
RE: Charging via USB-C - by Luke - 12-15-2019, 11:08 AM
Photo P{inebook Pro not charging Ome Ko 6 1,972 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,888 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,507 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,288 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,815 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,641 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,842 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,730 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,073 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,121 05-30-2020, 06:05 PM
