Rockpro64 not stable... crashes now and then.
Ok. thank you. In your link they are lots of different images. Which one are you using ? So I will be able to test with exact same firmware.
I will start to test rockpro64-debian-mrfixit-190531.img (old version, but seems to be the last debian release of mrfixit). But the kernel doesnt match with yours:
Linux ab-rock.lan 4.4.180 #1 SMP Fri May 31 17:07:08 EDT 2019 aarch64 GNU/Linux
I started the hexdump test anyway
edit: the hexdump test was ok (but I did only one pass), but the syncthing test was not ok.
root@ab-rock:~# [ 1371.252433] ata1: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
[ 1371.253154] ata1: irq_stat 0x00000040, connection status changed
[ 1371.253683] ata1: SError: { CommWake DevExch }
[ 1371.254155] ata1: hard resetting link
[ 1381.254144] ata1: softreset failed (1st FIS failed)
[ 1381.254593] ata1: hard resetting link
[ 1383.255370] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1383.285388] ata1.00: HPA detected: current 2930275055, native 2930277168
[ 1383.285998] ata1.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
[ 1383.286601] ata1.00: 2930275055 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1383.330393] ata1.00: configured for UDMA/133
[ 1383.330813] ata1: EH complete
[ 1383.331682] scsi 0:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
[ 1383.333163] sd 0:0:0:0: [sda] 2930275055 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 1383.333997] sd 0:0:0:0: [sda] Write Protect is off
[ 1383.334480] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1383.335120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1383.423350] sda: sda1
[ 1383.424862] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1417.038227] EXT4-fs (sda1): recovery complete
[ 1417.062188] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
root@ab-rock:~#
root@ab-rock:~#
root@ab-rock:~# mv /home/abdel/.config/syncthing/ /home/rock/.config
root@ab-rock:~# chown -R rock:rock /home/rock/.config/syncthing/
root@ab-rock:~# [ 2100.880059] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8009cda130
[ 2100.880892] Internal error: : 96000210 [#1] SMP
[ 2100.881291] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[ 2100.882087] CPU: 2 PID: 345 Comm: scsi_eh_0 Not tainted 4.4.180 #1
[ 2100.882628] Hardware name: Pine64 RockPro64 (DT)
[ 2100.883035] task: ffffffc0f33eec00 task.stack: ffffffc0ed258000
[ 2100.883562] PC is at ahci_scr_read+0x70/0x98
[ 2100.883942] LR is at sata_scr_read+0x88/0x94
[ 2100.884317] pc : [<ffffff800863a328>] lr : [<ffffff800861f67c>] pstate: 80000145
[ 2100.884962] sp : ffffffc0ed25ba60
[ 2100.885254] x29: ffffffc0ed25ba60 x28: 0000000000000000
[ 2100.885726] x27: ffffffc0ed1d5e80 x26: 0000000000000001
[ 2100.886198] x25: ffffffc0ed1d6280 x24: ffffffc0ed1d4000
[ 2100.886670] x23: 0000000000000000 x22: ffffffc0ed25bb38
[ 2100.887141] x21: ffffffc0ed1d5e80 x20: ffffffc0ed25bb38
[ 2100.887613] x19: 0000000000000001 x18: 0000000000000001
[ 2100.888085] x17: 00e8000035c2bf53 x16: 0000000000adefff
[ 2100.888558] x15: ffffffbdc0000000 x14: 0000000000000000
[ 2100.889030] x13: 0000000000000000 x12: 0000000000000000
[ 2100.889502] x11: 0000000000000000 x10: 0000000000000000
[ 2100.889973] x9 : 0000000000000000 x8 : ffffffc0ed1d6280
[ 2100.890445] x7 : 0000000000000000 x6 : ffffffc0ed1d62f8
[ 2100.890917] x5 : 0000000000000000 x4 : ffffff800908f948
[ 2100.891388] x3 : 0000000000000130 x2 : ffffffc0ed25bb38
[ 2100.891860] x1 : 0000000000000030 x0 : ffffff8009cda130
[ 2100.892333]
[ 2100.892333] PC: 0xffffff800863a2a8:
[ 2100.892769] a2a8 52800013 9135c421 97fe26d4 17ffffe2 a9bd7bfd 910003fd a90153f3 f90013f5
[ 2100.893522] a2c8 aa0003f5 2a0103f3 aa1e03e0 aa0203f4 d503201f f94002a3 7100127f f95a3c60
[ 2100.894274] a2e8 b9402c63 f9401801 53196063 91040063 f9400820 54000268 54000061 b9401821
[ 2100.895025] a308 36e80201 b00052a4 9124a084 91008084 b8735881 34000161 8b21c063 8b030000
[ 2100.895778] a328 b9400000 d5033d9f b9000280 52800000 a94153f3 f94013f5 a8c37bfd d65f03c0
[ 2100.896531] a348 128002a0 17fffffb a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d503201f
[ 2100.897284] a368 f9400260 f9400000 f95a3c00 f9401800 b9400000 36400120 52801fe0 b903be60
[ 2100.898035] a388 90006dc2 d0006981 91363442 913f8421 aa1303e0 97ff9803 f9400bf3 a8c27bfd
[ 2100.898789]
[ 2100.898789] LR: 0xffffff800861f5fc:
[ 2100.899224] f5fc a90153f3 a9025bf5 aa0003f3 2a0103f5 aa1e03e0 aa0203f6 d503201f f9400274
[ 2100.899976] f61c d283d000 8b000280 eb00027f 54000180 f95a2280 eb00027f 54000120 aa1603e2
[ 2100.900727] f63c 2a1503e1 aa1303e0 94005758 a94153f3 a9425bf5 a8c37bfd d65f03c0 aa1303e0
[ 2100.901477] f65c 97fffb18 34000100 f9400680 aa1603e2 2a1503e1 f9406c03 aa1303e0 d63f0060
[ 2100.902230] f67c 17fffff3 12800bc0 17fffff1 a9ba7bfd 910003fd a90153f3 a9025bf5 a90363f7
[ 2100.902980] f69c a9046bf9 aa0103f5 aa0203f6 aa0003f7 aa1e03e0 d503201f d00085b3 b94012a0
[ 2100.903733] f6bc f940e274 a94066b8 97eb7eb5 8b000280 cb160001 910173a2 f100003f 52800001
[ 2100.904483] f6dc 9a80a2d6 aa1703e0 97ffffc4 2a0003f5 350003c0 b9405fb4 f940e27a 12000e94
[ 2100.905237]
[ 2100.905237] SP: 0xffffffc0ed25b9e0:
[ 2100.905672] b9e0 ed25bb38 ffffffc0 00000000 00000000 ed1d4000 ffffffc0 ed1d6280 ffffffc0
[ 2100.906425] ba00 00000001 00000000 ed1d5e80 ffffffc0 00000000 00000000 ed25ba60 ffffffc0
[ 2100.907178] ba20 0861f67c ffffff80 ed25ba60 ffffffc0 0863a328 ffffff80 80000145 00000000
[ 2100.907929] ba40 00000000 00000000 00000000 00000000 ffffffff ffffffff 00000000 00000000
[ 2100.908680] ba60 ed25ba90 ffffffc0 0861f67c ffffff80 ed1d5e80 ffffffc0 ed1d4000 ffffffc0
[ 2100.909432] ba80 00000001 00000000 00000000 00000001 ed25bac0 ffffffc0 0862c5a0 ffffff80
[ 2100.910182] baa0 ed1d6280 ffffffc0 ed1d5e80 ffffffc0 ed1d7940 ffffffc0 00003008 00000000
[ 2100.910934] bac0 ed25bb70 ffffffc0 0862cd60 ffffff80 ed1d4000 ffffffc0 ed1d5e80 ffffffc0
[ 2100.911686]
[ 2100.911686] X0: 0xffffff8009cda0b0:
[ 2100.912122] a0b0
[ 2100.962281] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8009cda0b0
[ 2107.963106] BUG: spinlock lockup suspected on CPU#2, scsi_eh_0/345
[ 2107.963651] lock: 0xffffff80096e0018, .magic: dead4ead, .owner: scsi_eh_0/345, .owner_cpu: 2
[ 2107.964398] CPU: 2 PID: 345 Comm: scsi_eh_0 Not tainted 4.4.180 #1
[ 2107.964938] Hardware name: Pine64 RockPro64 (DT)
[ 2107.965343] Call trace:
[ 2107.965571] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[ 2107.966047] [<ffffff80080883e8>] show_stack+0x24/0x30
[ 2107.966494] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[ 2107.966941] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[ 2107.967378] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[ 2107.967879] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[ 2107.968414] [<ffffff8008088428>] die+0x34/0x1b4
[ 2107.968814] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 2107.969304] [<ffffff8008093324>] do_sea+0x80/0x94
[ 2107.969718] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 2107.970176] Exception stack(0xffffffc0ed25b4c0 to 0xffffffc0ed25b5f0)
[ 2107.970742] b4c0: ffffffc0f33eec00 0000008000000000 ffffffc0ed25b690 ffffff8008422884
[ 2107.971425] b4e0: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[ 2107.972110] b500: ffffff80098f5148 0000000000000000 ffffffc0ed25b530 ffffff80080eda14
[ 2107.972795] b520: 0000000000000005 0000000000000000 ffffffc0ed25b5d0 ffffff80080edb74
[ 2107.973479] b540: ffffffc0ed25b650 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[ 2107.974164] b560: ffffffc0ed25b71c ffffff8009cda0b0 0000000000000004 00000040ee86b000
[ 2107.974849] b580: 0000000000000002 ffffffc0ed25b720 ffffffc0ed25b71c 00000000ffffffff
[ 2107.975533] b5a0: ffffff80099137ec 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[ 2107.976218] b5c0: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[ 2107.976901] b5e0: 0000000000adefff 00e8000035c2bf53
[ 2107.977329] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 2107.977744] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[ 2107.978272] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[ 2107.978738] [<ffffff80080884ac>] die+0xb8/0x1b4
[ 2107.979139] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 2107.979627] [<ffffff8008093324>] do_sea+0x80/0x94
[ 2107.980040] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 2107.980499] Exception stack(0xffffffc0ed25b890 to 0xffffffc0ed25b9c0)
[ 2107.981061] b880: 0000000000000001 0000008000000000
[ 2107.981746] b8a0: ffffffc0ed25ba60 ffffff800863a328 ffffff800863a328 0000000080000145
[ 2107.982431] b8c0: 0000000000000025 ffffffc0ed1d6280 0000000000000001 ffffffc0ed1d5e80
[ 2107.983115] b8e0: ffffffc0f33eec00 ffffffc0ed25ba60 ffffff800861f67c ffffffc0ed25b930
[ 2107.983800] b900: ffffff80080825b8 0000000060000145 ffffff800976e0b8 0000000000000021
[ 2107.984484] b920: 0000008000000000 ffffff80098f55c0 ffffff8009cda130 0000000000000030
[ 2107.985169] b940: ffffffc0ed25bb38 0000000000000130 ffffff800908f948 0000000000000000
[ 2107.985853] b960: ffffffc0ed1d62f8 0000000000000000 ffffffc0ed1d6280 0000000000000000
[ 2107.986538] b980: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 2107.987222] b9a0: 0000000000000000 ffffffbdc0000000 0000000000adefff 00e8000035c2bf53
[ 2107.987906] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 2107.988322] [<ffffff800861f67c>] sata_scr_read+0x88/0x94
[ 2107.988792] [<ffffff800862c5a0>] ata_eh_link_autopsy+0x4c/0x740
[ 2107.989310] [<ffffff800862cd60>] ata_eh_autopsy+0xcc/0xdc
[ 2107.989786] [<ffffff8008634ba0>] sata_pmp_error_handler+0x34/0x7bc
[ 2107.990328] [<ffffff8008639c90>] ahci_error_handler+0x48/0x78
[ 2107.990833] [<ffffff800862f194>] ata_scsi_port_error_handler+0xe0/0x578
[ 2107.991412] [<ffffff800862f6b0>] ata_scsi_error+0x84/0xa4
[ 2107.991890] [<ffffff8008608bcc>] scsi_error_handler+0x13c/0x430
[ 2107.992410] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[ 2107.992832] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[ 2136.177855] Watchdog detected hard LOCKUP on cpu 2
[ 2136.178281] ------------[ cut here ]------------
[ 2136.178708] WARNING: at kernel/watchdog.c:352
[ 2136.179090] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[ 2136.179879]
[ 2136.180020] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.180 #1
[ 2136.180545] Hardware name: Pine64 RockPro64 (DT)
[ 2136.180951] task: ffffffc0f3288d80 task.stack: ffffffc0f3298000
[ 2136.181476] PC is at watchdog_timer_fn+0x190/0x2e8
[ 2136.181898] LR is at watchdog_timer_fn+0x190/0x2e8
[ 2136.182320] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[ 2136.182964] sp : ffffffc0f7eebdf0
[ 2136.183256] x29: ffffffc0f7eebdf0 x28: 0000000000000002
[ 2136.183728] x27: ffffff80096d7720 x26: ffffff8009698260
[ 2136.184200] x25: ffffffc0f7eee278 x24: ffffffc0f329bda0
[ 2136.184672] x23: 0000000000000000 x22: 00000000000007c1
[ 2136.185143] x21: ffffff80096d6000 x20: ffffff80096982d8
[ 2136.185615] x19: ffffff8009698000 x18: 0000000000000005
[ 2136.186087] x17: 00e800003c33ff53 x16: 0000000000adefff
[ 2136.186558] x15: 0000000000000000 x14: 000000000000000a
[ 2136.187030] x13: ffffff80898f48e7 x12: 0000000000000030
[ 2136.187503] x11: 0000000000000006 x10: ffffff80098f48ef
[ 2136.187975] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[ 2136.188446] x7 : 6574636574656420 x6 : ffffff80098f491d
[ 2136.188918] x5 : 00000000fffffffe x4 : 0000000000000002
[ 2136.189390] x3 : 00000040ee856000 x2 : 00000040ee856000
[ 2136.189862] x1 : 0000000000000001 x0 : 0000000000000026
[ 2136.190335]
[ 2136.190335] PC: 0xffffff800812c6b8:
[ 2136.190771] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 2136.191524] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 2136.192276] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 2136.193029] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 2136.193782] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 2136.194534] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 2136.195287] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 2136.196037] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 2136.196790]
[ 2136.196790] LR: 0xffffff800812c6b8:
[ 2136.197225] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 2136.197976] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 2136.198728] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 2136.199480] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 2136.200232] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 2136.200983] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 2136.201734] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 2136.202485] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 2136.203238]
[ 2136.203238] SP: 0xffffffc0f7eebd70:
[ 2136.203673] bd70 000007c1 00000000 00000000 00000000 f329bda0 ffffffc0 f7eee278 ffffffc0
[ 2136.204422] bd90 09698260 ffffff80 096d7720 ffffff80 00000002 00000000 f7eebdf0 ffffffc0
[ 2136.205175] bdb0 0812c738 ffffff80 f7eebdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 2136.205928] bdd0 096d6710 ffffff80 0000020d 00000000 00000000 00000080 f2c00028 ffffffc0
[ 2136.206679] bdf0 f7eebe60 ffffffc0 08103104 ffffff80 f7eee278 ffffffc0 f7eedc00 ffffffc0
[ 2136.207432] be10 57283cb7 000001f1 f7eedc80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 2136.208185] be30 098a07b8 ffffff80 57283cb7 000001f1 0812c5a8 ffffff80 f3288d80 ffffffc0
[ 2136.208938] be50 f7eee278 ffffffc0 096d6710 ffffff80 f7eebed0 ffffffc0 081036e8 ffffff80
[ 2136.209693]
[ 2136.209693] X6: 0xffffff80098f489d:
[ 2136.210128] 489c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.210880] 48bc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.211630] 48dc 00000000 00000001 00000000 30303020 32303330 33363130 34205d30 20636438
[ 2136.212381] 48fc 322e3633 39363930 58205d33 30203a36 66666678 38666666 38393030 39383466
[ 2136.213134] 491c 300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[ 2136.213885] 493c 33356662 70635f0a 32203a75 6463390a 30623061 6c6c690a 20656220 65736163
[ 2136.214637] 495c 6e657320 69746973 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[ 2136.215389] 497c 7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[ 2136.216140] 499c 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[ 2136.216894]
[ 2136.216894] X10: 0xffffff80098f486f:
[ 2136.217337] 486c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.218089] 488c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.218840] 48ac 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.219592] 48cc 00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[ 2136.220343] 48ec 322e3633 34333033 34205d33 20636538 322e3633 39383631 58205d34 203a3031
[ 2136.221096] 490c 66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[ 2136.221846] 492c 74617473 36203a65 30303030 0a356331 33356662 70635f0a 32203a75 6463390a
[ 2136.222597] 494c 30623061 6c6c690a 20656220 65736163 6e657320 69746973 0a216576 73203b29
[ 2136.223349] 496c 65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[ 2136.224102]
[ 2136.224102] X13: 0xffffff80898f4867:
[ 2136.224545] 4864 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.225298] 4884 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.226049] 48a4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.226803] 48c4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.227559] 48e4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.228310] 4904 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.229065] 4924 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.229817] 4944 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.230566] 4964 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.231322]
[ 2136.231322] X19: 0xffffff8009697f80:
[ 2136.231765] 7f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.232517] 7fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.233269] 7fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.234019] 7fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.234774] 8000 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.235527] 8020 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.236281] 8040 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.237035] 8060 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.237788]
[ 2136.237788] X20: 0xffffff8009698258:
[ 2136.238230] 8258 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.238982] 8278 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.239739] 8298 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.240495] 82b8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.241249] 82d8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.242002] 82f8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.242754] 8318 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.243509] 8338 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.244264]
[ 2136.244264] X21: 0xffffff80096d5f80:
[ 2136.244707] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.245459] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.246208] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.246958] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.247708] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.248460] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.249210] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.249961] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.250716]
[ 2136.250716] X24: 0xffffffc0f329bd20:
[ 2136.251159] bd20 00000000 00000000 f3288d80 ffffffc0 000001c0 00000000 08c6cdb0 ffffff80
[ 2136.251910] bd40 00000002 00000000 080913c4 ffffff80 f329bd60 ffffffc0 080914b8 ffffff80
[ 2136.252662] bd60 f329be70 ffffffc0 08c6d42c ffffff80 f329bdb0 ffffffc0 08cee258 ffffff80
[ 2136.253415] bd80 f24ffa10 ffffffc0 f24ff610 ffffffc0 f24ff800 ffffffc0 00000002 00000000
[ 2136.254168] bda0 f7ef2180 ffffffc0 ee856000 00000040 f7ef2180 ffffffc0 f329beb0 ffffffc0
[ 2136.254919] bdc0 ffffffff 00ffffff f5ed5e7f 0000000b 001d68fa 00000000 00000000 00000000
[ 2136.255672] bde0 f329bf50 ffffffc0 00000000 00000000 000009a0 00000000 0000011d 00000000
[ 2136.256423] be00 00000119 00000000 00000001 00000000 00000001 00000000 c0000000 ffffffbd
[ 2136.257173]
[ 2136.257173] X25: 0xffffffc0f7eee1f8:
[ 2136.257615] e1f8 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7eee210 ffffffc0
[ 2136.258367] e218 f7eee210 ffffffc0 f7eee220 ffffffc0 f7eee220 ffffffc0 0812b194 ffffff80
[ 2136.259120] e238 f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[ 2136.259871] e258 00000001 00000000 00000216 00000000 00000215 00000000 f328d100 ffffffc0
[ 2136.260622] e278 f7eee278 ffffffc0 f7eee0e8 ffffffc0 00000000 00000000 57283940 000001f1
[ 2136.261375] e298 57283940 000001f1 0812c5a8 ffffff80 f7eedc80 ffffffc0 00000000 0000000b
[ 2136.262126] e2b8 0812c57c ffffff80 63746177 676f6468 0000312f 00000000 00000215 00000000
[ 2136.262879] e2d8 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 2136.263630]
[ 2136.263630] X26: 0xffffff80096981e0:
[ 2136.264073] 81e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.264825] 8200 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.265581] 8220 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.266336] 8240 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.267091] 8260 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.267844] 8280 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.268596] 82a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.269350] 82c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.270104]
[ 2136.270104] X27: 0xffffff80096d76a0:
[ 2136.270546] 76a0 00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[ 2136.271297] 76c0 00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[ 2136.272049] 76e0 00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[ 2136.272800] 7700 00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[ 2136.273551] 7720 ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[ 2136.274304] 7740 ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[ 2136.275057] 7760 00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[ 2136.275808] 7780 0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 2136.276559]
[ 2136.276559] X29: 0xffffffc0f7eebd70:
[ 2136.277002] bd70 000007c1 00000000 00000000 00000000 f329bda0 ffffffc0 f7eee278 ffffffc0
[ 2136.277753] bd90 09698260 ffffff80 096d7720 ffffff80 00000002 00000000 f7eebdf0 ffffffc0
[ 2136.278506] bdb0 0812c738 ffffff80 f7eebdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 2136.279259] bdd0 096d6710 ffffff80 0000020d 00000000 00000000 00000080 f2c00028 ffffffc0
[ 2136.280010] bdf0 f7eebe60 ffffffc0 08103104 ffffff80 f7eee278 ffffffc0 f7eedc00 ffffffc0
[ 2136.280763] be10 57283cb7 000001f1 f7eedc80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 2136.281515] be30 098a07b8 ffffff80 57283cb7 000001f1 0812c5a8 ffffff80 f3288d80 ffffffc0
[ 2136.282266] be50 f7eee278 ffffffc0 096d6710 ffffff80 f7eebed0 ffffffc0 081036e8 ffffff80
[ 2136.283016]
[ 2136.283151] ---[ end trace dca43d00f74d00c6 ]---
[ 2136.283556] Call trace:
[ 2136.283776] Exception stack(0xffffffc0f7eebc10 to 0xffffffc0f7eebd40)
[ 2136.284340] bc00: ffffff8009698000 0000008000000000
[ 2136.285025] bc20: ffffffc0f7eebdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[ 2136.285710] bc40: 0000000000000026 0000000000000000 ffffffc0f7eebcf0 ffffff80080edb74
[ 2136.286394] bc60: ffffffc0f7eebd70 ffffff800937898b ffffff80096d6000 00000000000007c1
[ 2136.287079] bc80: 0000000000000000 ffffffc0f329bda0 ffffffc0f7eee278 ffffff8009698260
[ 2136.287762] bca0: ffffff80096d7720 0000000000000002 0000000000000004 ffffff8009692000
[ 2136.288447] bcc0: 0000000000000026 0000000000000001 00000040ee856000 00000040ee856000
[ 2136.289131] bce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[ 2136.289816] bd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[ 2136.290501] bd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[ 2136.291187] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[ 2136.291702] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[ 2136.292236] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[ 2136.292744] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[ 2136.293289] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[ 2136.293839] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[ 2136.294344] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[ 2136.294856] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[ 2136.295337] Exception stack(0xffffffc0f329bda0 to 0xffffffc0f329bed0)
[ 2136.295902] bda0: ffffffc0f7ef2180 00000040ee856000 ffffffc0f7ef2180 ffffffc0f329beb0
[ 2136.296586] bdc0: 00ffffffffffffff 0000000bf5ed5e7f 00000000001d68fa 0000000000000000
[ 2136.297271] bde0: ffffffc0f329bf50 0000000000000000 00000000000009a0 000000000000011d
[ 2136.297955] be00: 0000000000000119 0000000000000001 0000000000000001 ffffffbdc0000000
[ 2136.298640] be20: 0000000000adefff 00e800003c33ff53 0000000000000001 000001f15728394c
[ 2136.299324] be40: 0000000000000000 ffffffc0f1f10c00 0000000000000000 ffffff80098a0ce0
[ 2136.300009] be60: 0000000000000000 000001f1571908cd ffffff800983def0 0000000001193244
[ 2136.300693] be80: 0000000000000000 ffffffc0f329bed0 ffffff8008c43ccc ffffffc0f329bed0
[ 2136.301378] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f329bed0 ffffff8008c43ccc
[ 2136.302060] bec0: ffffffffffffffff 0000000000000000
[ 2136.302488] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 2136.302920] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[ 2136.303446] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[ 2136.303914] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[ 2136.304373] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[ 2136.304887] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[ 2136.305435] [<0000000001193188>] 0x1193188
Message from syslogd@localhost at Dec 22 10:18:00 ...
kernel:[ 2] Internal error: : 96000210 [#1] SMP
kernel:[ 2107.963106] BUG: spinlock lockup suspected on CPU#2, scsi_eh_0/345
kernel:[ 2107.963651] lock: 0xffffff80096e0018, .magic: dead4ead, .owner: scsi_eh_0/345, .owner_cpu: 2
RE: Rockpro64 not stable... crashes now and then. - by abdel - 12-22-2019, 03:55 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,597 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,819 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,289 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,741 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,441 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,472 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 2,938 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 4,652 01-13-2023, 06:21 PM
Last Post: misterc
