Reading the CPU temperature
(11-16-2019, 12:06 PM)xalius Wrote: Are you doing some bare metal programming? I see you have clock, is there maybe also a power register somewhere? Maybe have a look at the Linux driver ...
Yes, I looked at both the Linux and NetBSD drivers, and couldn't find anything beyond what I have. The drivers themselves rely on the device tree for clocks, but I followed the tree up as much as I could, and believe that all relevant clocks are enabled by default.
I'm running QNX on the board. Got the basics up (all 6 cores, MMU, GIC, timers, UART) but I'm afraid of ramping up the core frequency on the two clusters without monitoring the CPU temperature.
OK, got it to work. Probably just needed to be more careful with all the clocks:
// Assert reset.
out32(cru_regs + 0x438, (0x10001 << 8));
printf("CRU_SOFTRST_CON14=%x\n", in32(cru_regs + 0x438));
// Set up clocks
// HCLK_PERILP1, PCLK_PERILP1
out32(cru_regs + CRU_CLKSEL_CON25, 0x079f0187);
out32(cru_regs + CRU_CLKGATE_CON8, (0x10000 << 2));
// SCLK_TSADC
out32(cru_regs + CRU_CLKSEL_CON27, 0x83ff001f);
out32(cru_regs + CRU_CLKGATE_CON9, (0x10000 << 10));
// PCLK_TSADC
out32(cru_regs + CRU_CLKGATE_CON22, (0x10000 << 13));
// De-assert reset
usleep(20);
out32(cru_regs + 0x438, (0x10000 << 8));
// Whatever this is...
out32(grf_regs + 0x0e648, (0x10001 << 7));
out32(grf_regs + 0x0e64c, (0x10001 << 7));
usleep(20);
out32(grf_regs + 0x0e644, (0x10001 << 2));
out32(grf_regs + 0x0e64c, (0x10001 << 2));
usleep(100);
// Set up auto mode.
out32(tsadc_regs + TSADC_AUTO_PERIOD, 1875);
out32(tsadc_regs + TSADC_AUTO_PERIOD_HT, 1875);
out32(tsadc_regs + TSADC_HIGHT_INT_DEBOUNCE, 4);
out32(tsadc_regs + TSADC_HIGHT_TSHUT_DEBOUNCE, 4);
Reading the CPU temperature - by elahav - 11-16-2019, 10:57 AM
RE: Reading the CPU temperature - by xalius - 11-16-2019, 12:06 PM
RE: Reading the CPU temperature - by elahav - 11-16-2019, 02:37 PM
RE: Reading the CPU temperature - by xalius - 11-16-2019, 05:44 PM
  Cases and temperature davidm 3 7,576 04-29-2019, 02:58 AM
Last Post: evilbunny
