HDMI->DVI Works "solution"
(05-04-2016, 12:18 PM)Spaz Wrote:
(05-04-2016, 11:36 AM)Luke Wrote:
(05-04-2016, 08:27 AM)Spaz Wrote: Is there a way to override the device drivers and force RGB?
I'm not sure my cheaper Dell monitor at home has anything but RGB. Only one of my three work monitors has the option to go YPbPr. It doesn't seem to be a common option on older displays.
Think there is, but nothing that a mere mortal can do. I remember someone explained what to do, I tried looking for it, but couldnt find it for you ...
I'm going to try tonight and see what is possible. Seems like it should be a one liner in a config somewhere.
I think the xorg.conf might be my first stop.
Going to try this first. xorg.conf settings has color space options.
Section "Screen"
   Identifier     "Screen0"
   Device         "nvidia0"
   Monitor        "Monitor0"
   Option         "ColorRange" "Full"
#   Option         "ColorRange" "Limited"
#   Option         "ColorSpace" "YCbCr444"
   Option         "ColorSpace" "RGB"
   DefaultDepth    24
   Option         "ModeValidation" "NoVesaModes, NoXServerModes"
   Option         "ExactModeTimingsDVI" "True"
   SubSection     "Display"
      Depth       24
      Modes      "1920x1080_60" "1920x1080_24" "1920x1080_23.976"
   EndSubSection
EndSection
Sure thing. If you, by some miracle, manage to solve the problem make sure to let everyone know.
Just to let you know that you can now see bug status reports - and report new ones - on Lennyraposo's page: https://www.pine64.pro/
[edit]
and here:  Linux
http://forum.pine64.org/showthread.php?tid=598
Android
http://forum.pine64.org/showthread.php?tid=791
Remix OS
http://forum.pine64.org/showthread.php?tid=792
HDMI->DVI Works "solution" - by Luke - 04-28-2016, 11:51 AM
RE: HDMI->DVI Works "solution" - by tkaiser - 04-29-2016, 09:00 AM
RE: HDMI->DVI Works "solution" - by Luke - 04-29-2016, 07:04 PM
RE: HDMI->DVI Works "solution" - by pii100 - 05-03-2016, 07:42 PM
RE: HDMI->DVI Works "solution" - by Luke - 05-04-2016, 05:15 AM
RE: HDMI->DVI Works "solution" - by pine.tree - 05-04-2016, 06:23 AM
RE: HDMI->DVI Works "solution" - by Spaz - 05-04-2016, 08:27 AM
RE: HDMI->DVI Works "solution" - by Luke - 05-04-2016, 11:36 AM
RE: HDMI->DVI Works "solution" - by Spaz - 05-04-2016, 12:18 PM
RE: HDMI->DVI Works "solution" - by Luke - 05-04-2016, 12:40 PM
  Can anyone get the power switch works? victorfence 0 2,773 11-28-2017, 01:31 AM
Last Post: victorfence
  TvHeadend works beautifully coleshores 9 19,287 10-16-2017, 03:39 PM
Last Post: g_t_j
  Linux TouchLCD+HDMI sharmayogesh 3 6,874 04-14-2017, 01:23 PM
Last Post: sharmayogesh
  HDMI 1080P Ophir 1 4,717 07-27-2016, 08:17 PM
Last Post: Ghost
  DTS options for HDMI-DVI adapters xalius 0 2,735 07-07-2016, 09:57 AM
Last Post: xalius
  HDMI overscan problem Terra854 10 19,441 05-30-2016, 10:12 PM
Last Post: gdjsky01
  HDMI Overscan / Underscan Dygaer 1 4,911 04-28-2016, 07:40 AM
Last Post: dhardingham
