(11-08-2019, 04:16 PM)cristobalhdez Wrote: I'm testing Manjaro on my PBP.
I can't connect to the 5ghz WIFI.
I'm able to see only 2.4 ghz networks.
I have tried it and it works fine. I will try to do a more details test this time and get back to you.
(11-08-2019, 05:15 PM)Arglebargle Wrote: I tested briefly last night and had issues with the wifi continuing to flake out after applying the powersave workaround and restarting the daemon and/or rebooting. Known issues aside the build seemed to work well, hard to do much with it with 10 minutes of network connectivity though.
Yes it is just a workaround and not a complete fix. For most people it is working fine with the TLP workaround. We shall find a permanent fix soon.
(11-08-2019, 08:36 PM)belfastraven Wrote: Question:  Obviously people are getting output on their powerbook screens, but I am not.  Output is fine through the serial uart; I can log into the initial boot (as root) and set up an account,  which I can then use  (through serial uart) when system reboots,  but there is never any output on the PBP, itself.  It doesn't matter whether I have the serial connection plugged into the headphone jack or not.  Are those of you who are succesfully getting output using  serial uart,(i.e. have switch 9 moved from its default position)?  Are you booting from SD?
Thanks for any info/help.
There are some users who have reported this. Thank you for reporting it here. I think this have something to do with the new LCD drivers. We have not found anything for this yet, Once we get some lead on this issue then we will be able to get a solution.
I'm having this problem with Manjaro intermittently. I feel like it works fine for a while then i reboot and the screen never comes on. It does boot, just no screen.
They specifically pointed out that the display drivers are flakey, I'm accounting it to that.
I think you're right Display drivers seems flakey but we're working on it and should be able to find some solution.
Currently we're working on finding s Wifi & Audio Fix.
Stay connected to get the update's & Thank you for all the feedback's.
Manjaro ARM Team.
no output on laptop screen - by belfastraven - 11-08-2019, 08:36 PM
RE: no output on laptop screen - by tsago - 11-09-2019, 04:46 PM
RE: Manjaro - PineBook Pro - Preview Released - by spikerguy - 11-09-2019, 04:18 AM
AUR pakcage typo for notes-tree ? - by dhosh - 02-06-2020, 09:54 AM
Open JRE available for Manjaro? - by dhosh - 02-06-2020, 04:13 PM
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,855 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,306 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 10,195 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,678 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,124 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,458 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 89,999 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,963 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,500 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 2,903 03-08-2024, 08:41 AM
