(11-08-2019, 08:36 PM)belfastraven Wrote: Question:  Obviously people are getting output on their powerbook screens, but I am not.  Output is fine through the serial uart; I can log into the initial boot (as root) and set up an account,  which I can then use  (through serial uart) when system reboots,  but there is never any output on the PBP, itself.  It doesn't matter whether I have the serial connection plugged into the headphone jack or not.  Are those of you who are succesfully getting output using  serial uart,(i.e. have switch 9 moved from its default position)?  Are you booting from SD?
Thanks for any info/help.
I'm having this problem with Manjaro intermittently. I feel like it works fine for a while then i reboot and the screen never comes on. It does boot, just no screen.
They specifically pointed out that the display drivers are flakey, I'm accounting it to that.
no output on laptop screen - by belfastraven - 11-08-2019, 08:36 PM
RE: no output on laptop screen - by electriccrowbar - 11-08-2019, 10:17 PM
RE: no output on laptop screen - by tsago - 11-09-2019, 04:46 PM
AUR pakcage typo for notes-tree ? - by dhosh - 02-06-2020, 09:54 AM
Open JRE available for Manjaro? - by dhosh - 02-06-2020, 04:13 PM
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,855 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,306 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 10,195 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,678 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,124 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,458 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 89,999 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,963 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,500 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 2,903 03-08-2024, 08:41 AM
