A true mainline Linux Kernel for the Pinebook Pro
#66
I used debootstrap to extract a Debian sid arm64 userland and recompiled the tsys kernel with the following flags:
CONFIG_MODULE_SIG_FORMAT=y
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_ASM_MODVERSIONS=y
CONFIG_MODULE_SIG=y
CONFIG_MODULE_SIG_SHA256=y
CONFIG_MODULE_SIG_HASH="sha256"
CONFIG_MODULES_TREE_LOOKUP=y
Then the debian userland tools (modprobe, etc.) were able to load the kernel modules.
1 big ext4 partition on a SD card, copied u-boot to the 32768 byte offset, installed kernel, modules, headers and (important!) the device tree from tsys/linux-pinebookpro.
Graphics also work, but I wasn't able to get xf86-video-fbturbo-git working.
RE: A true mainline Linux Kernel for the Pinebook Pro - by manawyrm - 11-29-2019, 06:43 AM
5.12 - by kalpazanius - 04-26-2021, 04:38 PM
RE: 5.12 - by ramsey - 06-19-2021, 05:36 PM
RE: 5.12 - by linuxad - 06-20-2021, 09:26 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 1,058 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 767 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 556 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 356 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 2,620 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 3,842 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 3,083 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 3,360 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 101,160 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 2,503 11-23-2023, 07:37 AM
