A true mainline Linux Kernel for the Pinebook Pro
#61
(11-28-2019, 04:17 PM)DrYak Wrote: @tsys : One more question regarding the upstream kernel - do you currently enable 32bit userland ?
Sorry. This has not really been my main focus. My defconfig does not enable a 32 bit userland. However you can easily do so by setting CONFIG_COMPAT to y.
How is WiFi testing going? Did you experience any crashes since switching to the other firmware?
(11-28-2019, 05:04 PM)Arwen Wrote: @tsys & @DrYak, I too would like both 32 and 64 bit userland.
Most everything can stay at 32 bit. But, somethings may work better at one or the other.
Sure. Enabling it in the kernel is easy. However, ARMv8 code will have significantly better performance. Thus only applications that do absolutly need to be run as 32 bit binaries like widevine should be run in compat mode.
(11-28-2019, 06:14 PM)Hexxeh Wrote: Trying to boot this kernel with the stock Debian image that comes pre-installed. I built the defconfig, copied the Image and DTB onto /boot, modules into /lib/modules. It starts to boot, and then I see serial output, but suddenly after the following, it becomes garbage:
[   12.051588] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[   12.065983] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
[   12.068329] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
Has anyone else seen this? I'm using the 1500000 baud rate, and that works fine for u-boot output and early kernel output until this point. I've tried a few other common baud rates at this point, but nothing shows reasonable output.
Yes, I've seen that before. There is probably no connection between the messages and the weird baudrate though. I've had my pinebook use weird baudrates before. Due to differences in libkmod the debian userland might be unable to load modules compiled from my kernel tree. That might be why your system is not working as expected. I'd suggest installing Manjaro to a Micro SD Card or even the eMMC flash. There the kernel will work properly.
Manjaro ARM
Kernel dev
Buy me a coffee
RE: A true mainline Linux Kernel for the Pinebook Pro - by tsys - 11-28-2019, 10:23 PM
5.12 - by kalpazanius - 04-26-2021, 04:38 PM
RE: 5.12 - by ramsey - 06-19-2021, 05:36 PM
RE: 5.12 - by linuxad - 06-20-2021, 09:26 AM
  Window Maker Live for Pinebook Pro vajak 8 1,091 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,330 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 2,172 07-27-2025, 12:30 AM
Last Post: fnosai
  Boot Order in Pinebook Pro food 11 11,209 03-28-2025, 10:08 AM
Last Post: DrYak
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,202 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 4,707 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,878 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 2,917 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,257 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 9,172 03-31-2024, 10:11 AM
Last Post: u974615
