A true mainline Linux Kernel for the Pinebook Pro
#47
Following up on the no display be aware that the pinebook_pro_defconfig is a distro-like config and is highy modular. The display will not come up until the rootfs (or initrd) comes up and the appropriate drm modules are loaded.
Thus if you didn't copy the modules to the rootfs (or your kernel command-line doesn't mount the rootfs correclty) then the display will never come up...
(if you did copy the modules then be patient, it takes a long time to initialize the kernel... the log messages make it look like CPU0 is clocked *very* slowly when u-boot hands it over)
RE: A true mainline Linux Kernel for the Pinebook Pro - by danielt - 11-18-2019, 05:50 AM
5.12 - by kalpazanius - 04-26-2021, 04:38 PM
RE: 5.12 - by ramsey - 06-19-2021, 05:36 PM
RE: 5.12 - by linuxad - 06-20-2021, 09:26 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 1,001 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 734 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 548 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 349 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 2,596 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 3,767 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 3,045 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 3,338 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 100,755 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 2,471 11-23-2023, 07:37 AM
