Permanent Watermark?
So i finally went ahead and pulled the top of the bezel loose so i could see and get my finger nails in there. It was a plastic sheet as we expected, but there was no way to get to it with the bezel still on ( as i suspected ). Not sure,but the lower part of the bezel may be glued on ? I didnt force it as i had just enough room only removing the 2 screws on top and unsnapping it there. No reason to risk more.
But its off and the print is gone with it.. so that is all that matters Smile
(11-04-2019, 09:19 PM)fire219 Wrote: That is in fact the screen protector used when the bare screens are shipped to the factory. If you can get a grasp on it, it should be removable.
I do not know if it is possible to remove the bezel without damaging the screen.
Somehow i missed this post, but i did end up getting it off ( see the post above )..
thanks for the help tho Smile
Permanent Watermark? - by Nurb432 - 11-04-2019, 12:06 PM
RE: Permanent Watermark? - by tophneal - 11-04-2019, 12:57 PM
RE: Permanent Watermark? - by Nurb432 - 11-04-2019, 01:08 PM
RE: Permanent Watermark? - by tophneal - 11-04-2019, 01:18 PM
RE: Permanent Watermark? - by Nurb432 - 11-04-2019, 01:32 PM
RE: Permanent Watermark? - by Kochise - 11-04-2019, 02:29 PM
RE: Permanent Watermark? - by Nurb432 - 11-04-2019, 02:49 PM
RE: Permanent Watermark? - by fire219 - 11-04-2019, 04:44 PM
RE: Permanent Watermark? - by Nurb432 - 11-04-2019, 04:55 PM
RE: Permanent Watermark? - by NSW - 11-04-2019, 05:41 PM
RE: Permanent Watermark? - by Nurb432 - 11-05-2019, 06:27 AM
RE: Permanent Watermark? - by Kochise - 11-05-2019, 06:38 AM
RE: Permanent Watermark? - by Nurb432 - 11-05-2019, 07:06 AM
RE: Permanent Watermark? - by fire219 - 11-04-2019, 09:19 PM
RE: Permanent Watermark? - by NotYourLoginId - 11-05-2019, 12:12 PM
RE: Permanent Watermark? - by Nurb432 - 11-05-2019, 12:29 PM
RE: Permanent Watermark? - by Nurb432 - 11-06-2019, 05:28 PM
