LSI SAS3082E-R
Thanks for your input, I got the card to recognize in lspci.  First try was max_link_speed 1 and num_lanes 1, the rockpro booted but lspci was blank.
I changed num-lanes to 4 and now I have lspci output!  Still on link speed 1 though...
Here's the lspci output and dmesg is attached.
01:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
       Subsystem: IBM SAS1068E PCI-Express Fusion-MPT SAS
       Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
       Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
       Interrupt: pin A routed to IRQ 243
       Region 0: I/O ports at <unassigned> [disabled]
       Region 1: Memory at fa210000 (64-bit, non-prefetchable) [disabled] [size=16K]
       Region 3: Memory at fa200000 (64-bit, non-prefetchable) [disabled] [size=64K]
       [virtual] Expansion ROM at fa000000 [disabled] [size=2M]
       Capabilities: [50] Power Management version 2
               Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
               Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
       Capabilities: [68] Express (v1) Endpoint, MSI 00
               DevCap: MaxPayload 4096 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                       ExtTag+ AttnBtn- AttnInd- PwrInd- RBE- FLReset- SlotPowerLimit 0.000W
               DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                       RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                       MaxPayload 128 bytes, MaxReadReq 512 bytes
               DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
               LnkCap: Port #0, Speed 2.5GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
                       ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
               LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                       ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
               LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
       Capabilities: [98] MSI: Enable- Count=1/1 Maskable- 64bit+
               Address: 0000000000000000  Data: 0000
       Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
               Vector table: BAR=1 offset=00002000
               PBA: BAR=1 offset=00003000
       Capabilities: [100 v1] Advanced Error Reporting
               UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
               UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
               UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
               CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
               CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
               AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
.txt   dmesg_lanes_4_speed_1.txt (Size: 81.68 KB / Downloads: 393)
LSI SAS3082E-R - by kram0000 - 11-01-2019, 03:05 PM
RE: LSI SAS3082E-R - by kram0000 - 11-02-2019, 11:54 AM
RE: LSI SAS3082E-R - by t4_4t - 11-04-2019, 01:52 AM
RE: LSI SAS3082E-R - by kram0000 - 11-04-2019, 05:57 PM
RE: LSI SAS3082E-R - by t4_4t - 11-04-2019, 08:36 PM
RE: LSI SAS3082E-R - by kram0000 - 11-05-2019, 11:26 AM
RE: LSI SAS3082E-R - by kram0000 - 11-05-2019, 12:27 PM
RE: LSI SAS3082E-R - by t4_4t - 11-05-2019, 08:34 PM
RE: LSI SAS3082E-R - by kram0000 - 11-14-2019, 12:21 AM
RE: LSI SAS3082E-R - by AndrewC78 - 05-10-2020, 05:40 AM
RE: LSI SAS3082E-R - by kram0000 - 09-13-2020, 08:59 PM
