LSI SAS3082E-R
Thanks for the reply.  I changed loglevel to 6 and got a new capture.  Not really sure where to go from here, what should I look into to work on this?  I think the synchronous external abort errors are the problem, but I don't know how to troubleshoot further.
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 249
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
FwPartOffset=2000 , 0
StorageInit ok = 44119
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xd35dc
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  3.9 GiB
Sysmem: init
Relocation Offset is: f5bfa000
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
               DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled
               DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
                LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
             SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled
                  dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
              vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)
       vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
          vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
        vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, disabled | suspend     -61uV, enabling
              vcc5v0-sys@     vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
   vcc12v-pcie-regulator@    vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV
             vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)
MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   serial
Err:   serial
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Bootdev(atags): mmc 1
PartType: DOS
get part misc fail -1
boot mode: None
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
 aplll 816000 KHz
 apllb 24000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
 aclk_perihp 133333 KHz
 hclk_perihp 66666 KHz
 pclk_perihp 33333 KHz
 aclk_perilp0 266666 KHz
 hclk_perilp0 88888 KHz
 pclk_perilp0 44444 KHz
 hclk_perilp1 100000 KHz
 pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
load_android_image: Can't find part: boot
Android boot failed, error -1.
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
415 bytes read in 5 ms (81.1 KiB/s)
1: ROCKPRO
Retrieving file: /Image
reading /Image
25612296 bytes read in 2715 ms (9 MiB/s)
append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current loglevel=6
Retrieving file: /rk3399-rockpro64.dtb
reading /rk3399-rockpro64.dtb
96363 bytes read in 14 ms (6.6 MiB/s)
## Flattened Device Tree blob at 08300000
  Booting using the fdt blob at 0x8300000
  Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 3855.951 ms
Starting kernel ...
[    0.000000] Linux version 4.4.180 (adam@adam-vb) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08) ) #1 SMP Fri May 31 17:07:08 EDT 2019
[    0.000000] Kernel command line: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current loglevel=6 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff80095a0000 - 0xffffff80096d0000   (  1216 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008fa0000   ( 15488 KB)
[    0.000000]     .rodata : 0xffffff8008fa0000 - 0xffffff80095a0000   (  6144 KB)
[    0.000000]       .data : 0xffffff80096d0000 - 0xffffff80098ed008   (  2165 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.561441] vcc1v8_sdio: regulator get failed, ret=-517
[    0.562255] vcc1v8_wifi: regulator get failed, ret=-517
[    0.563788] vcc1v8_pcie: regulator get failed, ret=-517
[    0.567385] SCSI subsystem initialized
[    0.613045] FS-Cache: Loaded
[    0.622128] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.630946] Initialise system trusted keyring
[    0.640281] NFS: Registering the id_resolver key type
[    0.640770] Key type id_resolver registered
[    0.641169] Key type id_legacy registered
[    0.648596] Key type asymmetric registered
[    0.648997] Asymmetric key parser 'x509' registered
[    0.651188] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[    0.659057] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    0.660920] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    0.662507] rk-vcodec ff660000.rkvdec: could not find power_model node
[    0.678062] Unable to detect cache hierarchy for CPU 0
[    0.686608] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    0.762386] Rockchip WiFi SYS interface (V1.00) ...
[    0.764740] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    0.769651] rockchip-dwc3 usb1: fail to get drvdata hcd
[    0.854095] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.854708] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.876095] fusb302 4-0022: Can't get property of role, set role to default DRP
[    0.893635] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    0.909152] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    0.966849] Bridge firewalling registered
[    0.968723] Key type dns_resolver registered
[    0.969742] Registered cp15_barrier emulation handler
[    0.970393] Registered setend emulation handler
[    0.971502] Loading compiled-in X.509 certificates
[    0.973582] phy phy-ff770000.syscon:usb2-phy@e450.5: Failed to get VBUS supply regulator
[    0.982074] rockchip-drm display-subsystem: failed to parse loader memory
[    1.033346] xhci-hcd xhci-hcd.7.auto: Host not halted after 16000 microseconds.
[    1.033986] xhci-hcd xhci-hcd.7.auto: Host controller not halted, aborting reset.
[    1.233980] es8316 1-0011: ASoC: Failed to create Left Hp mixer debugfs file
[    1.234648] es8316 1-0011: ASoC: Failed to create Right Hp mixer debugfs file
[    1.235291] es8316 1-0011: ASoC: Failed to create HPCP L debugfs file
[    1.235859] es8316 1-0011: ASoC: Failed to create HPCP R debugfs file
[    1.236441] es8316 1-0011: ASoC: Failed to create HPVOL L debugfs file
[    1.237022] es8316 1-0011: ASoC: Failed to create HPVOL R debugfs file
[    1.239778] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[    1.240417] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[    1.241043] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
[    1.241788] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[    1.242576] asoc-simple-card: probe of spdif-sound failed with error -22
[    1.245744] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r)
[    1.246403] ======== dhd_wlan_init_plat_data ========
[    1.246854] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[    1.247377] dhd_wlan_init_gpio: oob_irq=70, oob_irq_flags=0x414
[    1.247892] dhd_wifi_platform_load: Enter
[    1.248272] Power-up adapter 'DHD generic adapter'
[    1.257835] wifi_platform_set_power = 1
[    1.258193] ======== PULL WL_REG_ON(-1) HIGH! ========
[    1.364978] mmcblk0: error -5 transferring data, sector 530000, nr 144, cmd response 0x900, card status 0xb00
[    1.365888] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    1.381049] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    1.559174] wifi_platform_bus_enumerate device present 1
[    1.559651] ======== Card detection to detect SDIO card! ========
[    1.560284] sdio: host isn't  initialization successfully.
[    1.574774] mmc0: tried to reset card
[    1.718534] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    1.726303] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[    1.728821] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[    1.755350] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.756698] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.761148] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.762126] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[    1.803783] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.804752] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.805807] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.807036] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.902435] systemd[1]: Configuration file /lib/systemd/system/partition-bootup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    1.913114] systemd[1]: Starting of Arbitrary Executable File Formats File System Automount Point not supported.
[UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice System Slice.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on Journal Socket.
        Starting Remount Root and Kernel File Systems...
        Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
        Mounting POSIX Message Queue File System...
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote File Systems.
        Starting Restore / save the current clock...
[  OK  ] Created slice system-serial\x2dgetty.slice.
        Starting Load Kernel Modules...
[  OK  ] Listening on Syslog Socket.
        Starting Journal Service...
        Mounting Debug File System...
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted Debug File System.
        Mounting Configuration File System...
        Starting Apply Kernel Variables...
        Mounting FUSE Control File System...
        Starting Create Static Device Nodes in /dev...
        Starting udev Coldplug all Devices...
        Starting Load/Save Random Seed...
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Static Device Nodes in /dev.
        Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
        Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Journal Service.
        Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
        Starting Create Volatile Files and Directories...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Reached target System Time Synchronized.
        Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target Sound Card.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
[    2.354308] ff100000.saradc supply vref not found, using dummy regulator
[    2.407705] rockchip-pcie f8000000.pcie: missing optional "memory-region" property
[    2.408388] rockchip-pcie f8000000.pcie: missing optional "rockchip,dma_trx_enabled" property
[    2.409140] rockchip-pcie f8000000.pcie: missing optional "rockchip,deferred" property
        Starting LSB: IPv4 DHCP client with IPv4LL support...
        Starting Login Service...
        Starting System Logging Service...
[  OK  ] Started Boot and Home Patition Mount Service.
        Starting LSB: Starts and stops Wicd...
        Starting Save/Restore Sound Card State...
[  OK  ] Started Regular background program processing daemon.
        Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started System Logging Service.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Network.
        Starting OpenBSD Secure Shell server...
        Starting Permit User Sessions...
[  OK  ] Reached target Network is Online.
        Starting LSB: Start NTP daemon...
        Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started LSB: IPv4 DHCP client with IPv4LL support.
[  OK  ] Started LSB: Start NTP daemon.
[    2.788438] FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[  OK  ] Started OpenBSD Secure Shell server.
[    2.935464] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014100000
[    2.936278] Internal error: : 96000210 [#1] SMP
[    2.936679] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[    2.937479] CPU: 0 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[    2.938050] Hardware name: Pine64 RockPro64 (DT)
[    2.938469] Workqueue: deferwq deferred_probe_work_func
[    2.938931] task: ffffffc0f1c23600 task.stack: ffffffc0f1564000
[    2.939460] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    2.939911] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    2.940363] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    2.941007] sp : ffffffc0f15677e0
[    2.941300] x29: ffffffc0f15677e0 x28: 0000000000000000
[    2.941773] x27: 0000000000000001 x26: 0000000000000000
[    2.942245] x25: 0000000000000000 x24: ffffffc0ef61d000
[    2.942717] x23: 0000000000000000 x22: 0000000000000004
[    2.943190] x21: ffffffc0f14f9028 x20: ffffffc0f156786c
[    2.943661] x19: ffffff8014100000 x18: 0000000000000005
[    2.944133] x17: 0000000000000000 x16: 0000000000000000
[    2.944605] x15: 0000000000000000 x14: 000000000000000a
[    2.945080] x13: ffffff80898f48e7 x12: 0000000000000030
[    2.945565] x11: 0000000000000006 x10: ffffff80098f48ef
[    2.946037] x9 : 0000000005f5e0ff x8 : 6e696e6e61637320
[    2.946509] x7 : 3a31303a30303030 x6 : ffffff80098f4914
[    2.946982] x5 : ffffff80084a10bc x4 : 0000000000000000
[    2.947454] x3 : 000000000000000b x2 : 0000000000000800
[    2.947925] x1 : ffffff8012c00008 x0 : ffffff8014000000
[    2.948399]
[    2.948399] PC: 0xffffff80084a11a0:
[    2.948836] 11a0  54fffd01[    2.949003] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency
[    2.949639]  39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[    2.950296] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[    2.951049] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[    2.951802] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[    2.952555] 1220  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[    2.953307] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[    2.954057] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[    2.954808] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[    2.955564]
[    2.955564] LR: 0xffffff80084a1190:
[    2.955999] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[    2.956750] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[    2.957503] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[    2.958253] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[    2.959004] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[    2.959754] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[    2.960508] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[    2.961260] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[    2.962012]
[    2.962012] SP: 0xffffffc0f1567760:
[    2.962447] 7760  00000004 00000000 00000000 00000000 ef61d000 ffffffc0 00000000 00000000
[    2.963198] 7780  00000000 00000000 00000001 00000000 00000000 00000000 f15677e0 ffffffc0
[    2.963949] 77a0  084a1210 ffffff80 f15677e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[    2.964703] 77c0  00100000 00000000 f156786c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[    2.965455] 77e0  f1567820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 ef61d000 ffffffc0
[    2.966206] 7800  00000000 00000000 00000140 00000000 f15678ec ffffffc0 00000000 00000000
[    2.966957] 7820  f1567870 ffffffc0 0848210c ffffff80 f15678ec ffffffc0 ef61d000 ffffffc0
[    2.967710] 7840  ef61d000 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[    2.968462]
[    2.968462] X0: 0xffffff8013ffff80:
[    2.968897] ff80  ******** ******** ******** ******** ******** ******** ******** ********
[    2.969652] ffa0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.970406] ffc0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.971157] ffe0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.971912] 0000
[    2.972071] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[    3.976000] vendor storage:20160801 ret = -1
[    4.491076] random: nonblocking pool is initialized
[    9.972895] BUG: spinlock lockup suspected on CPU#0, kworker/u12:3/159
[    9.973475]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:3/159, .owner_cpu: 0
[    9.974251] CPU: 0 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[    9.974820] Hardware name: Pine64 RockPro64 (DT)
[    9.975233] Workqueue: deferwq deferred_probe_work_func
[    9.975693] Call trace:
[    9.975918] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[    9.976394] [<ffffff80080883e8>] show_stack+0x24/0x30
[    9.976840] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[    9.977287] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[    9.977724] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[    9.978225] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[    9.978759] [<ffffff8008088428>] die+0x34/0x1b4
[    9.979160] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.979650] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.980065] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.980525] Exception stack(0xffffffc0f1567240 to 0xffffffc0f1567370)
[    9.981090] 7240: ffffffc0f1c23600 0000008000000000 ffffffc0f1567410 ffffff8008422884
[    9.981774] 7260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[    9.982459] 7280: ffffff80098f5148 0000000000000000 ffffffc0f15672b0 ffffff80080eda14
[    9.983144] 72a0: 0000000000000005 0000000000000000 ffffffc0f1567350 ffffff80080edb74
[    9.983829] 72c0: ffffffc0f15673d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[    9.984513] 72e0: ffffffc0f156749c ffffff8014000000 0000000000000004 00000040ee841000
[    9.985198] 7300: 0000000000000002 ffffffc0f15674a0 ffffffc0f156749c 00000000ffffffff
[    9.985881] 7320: ffffff800991039f 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[    9.986565] 7340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[    9.987249] 7360: 0000000000000000 0000000000000000
[    9.987679] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.988094] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[    9.988621] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[    9.989087] [<ffffff80080884ac>] die+0xb8/0x1b4
[    9.989487] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.989975] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.990389] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.990846] Exception stack(0xffffffc0f1567610 to 0xffffffc0f1567740)
[    9.991410] 7600:                                   ffffff8014100000 0000008000000000
[    9.992095] 7620: ffffffc0f15677e0 ffffff80084a1220 ffffffc0ef61d120 000000000000006e
[    9.992779] 7640: ffffffc0f15677f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[    9.993464] 7660: ffffffc0f1567752 0000000000000000 ffffffc0f1567680 ffffff8009692000
[    9.994149] 7680: 0000000000000140 00000000093c1b86 ffffffc0f1567860 ffffffc0f1567860
[    9.994833] 76a0: ffffffc0f1567830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[    9.995517] 76c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[    9.996202] 76e0: ffffff80098f4914 3a31303a30303030 6e696e6e61637320 0000000005f5e0ff
[    9.996887] 7700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[    9.997571] 7720: 000000000000000a 0000000000000000 0000000000000000 0000000000000000
[    9.998255] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.998671] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[    9.999229] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[    9.999794] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[   10.000329] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[   10.000795] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[   10.001308] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[   10.001804] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[   10.002325] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[   10.002852] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[   10.003350] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[   10.003929] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[   10.004457] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[   10.004962] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[   10.005489] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[   10.006024] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[   10.006513] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[   10.007002] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[   10.007523] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[   10.008012] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[   10.008563] [<ffffff80080b2350>] process_one_work+0x224/0x368
[   10.009068] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[   10.009552] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[   10.009974] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[   12.797988] NETDEV WATCHDOG: eth0 (rk_gmac-dwmac): transmit queue 0 timed out
[   12.798640] ------------[ cut here ]------------
[   12.799044] WARNING: at net/sched/sch_generic.c:306
[   12.799469] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[   12.800252]
[   12.800388] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.180 #1
[   12.800911] Hardware name: Pine64 RockPro64 (DT)
[   12.801314] task: ffffffc0f328b600 task.stack: ffffffc0f32a4000
[   12.801838] PC is at dev_watchdog+0x1a0/0x238
[   12.802220] LR is at dev_watchdog+0x1a0/0x238
[   12.802601] pc : [<ffffff8008d9ecac>] lr : [<ffffff8008d9ecac>] pstate: 00000145
[   12.803243] sp : ffffffc0f7f2adf0
[   12.803534] x29: ffffffc0f7f2adf0 x28: 0000000000000000
[   12.804004] x27: dead000000000200 x26: 00000000ffffffff
[   12.804473] x25: 0000000000000180 x24: 0000000000000004
[   12.804942] x23: ffffffc0f1d93280 x22: ffffff800989f000
[   12.805411] x21: ffffffc0f25523e0 x20: 0000000000000000
[   12.805879] x19: ffffffc0f2552000 x18: 0000000000000005
[   12.806349] x17: 0000000000000000 x16: ffffff80081ede5c
[   12.806818] x15: 0000000000000000 x14: 000000000000000a
[   12.807287] x13: ffffff80898f48e7 x12: 0000000000000030
[   12.807756] x11: 0000000000000006 x10: ffffff80098f48ef
[   12.808225] x9 : 0000000005f5e0ff x8 : 756575712074696d
[   12.808693] x7 : 736e617274203a29 x6 : ffffff80098f4938
[   12.809163] x5 : 0000000000000000 x4 : 0000000000000000
[   12.809632] x3 : 0000000000000000 x2 : ffffffc0f7f2e348
[   12.810101] x1 : 00000040ee895000 x0 : 0000000000000041
[   12.810570]
[   12.810570] PC: 0xffffff8008d9ec2c:
[   12.811003] ec2c  f9402661 3607fa61 f9402661 721e003f 54fffa01 52800014 f00049a4 f9405001
[   12.811750] ec4c  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[   12.812500] ec6c  ab01007f 540002e5 f9405401 b0005816 91000421 f9005401 3971eac0 35000180
[   12.813245] ec8c  aa1303e0 97ff81a4 2a1403e3 aa0003e2 aa1303e1 b0003ae0 9120e800 97cf092d
[   12.813990] ecac  d4210000 52800020 3931eac0 f9410260 f9403801 aa1303e0 d63f0020 14000005
[   12.814735] eccc  11000694 91060000 6b02029f 54fffb81 b983fa61 f00049a0 f940e000 8b000020
[   12.815479] ecec  97cd837d aa0003e1 91104260 97cd8c4e 35fff400 d538d081 f9423260 8b010000
[   12.816227] ed0c  885f7c03 11000463 88027c03 35ffffa2 17ffff98 f941e276 52800040 9bb75a96
[   12.816973]
[   12.816973] LR: 0xffffff8008d9ec2c:
[   12.817406] ec2c  f9402661 3607fa61 f9402661 721e003f 54fffa01 52800014 f00049a4 f9405001
[   12.818151] ec4c  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[   12.818898] ec6c  ab01007f 540002e5 f9405401 b0005816 91000421 f9005401 3971eac0 35000180
[   12.819643] ec8c  aa1303e0 97ff81a4 2a1403e3 aa0003e2 aa1303e1 b0003ae0 9120e800 97cf092d
[   12.820387] ecac  d4210000 52800020 3931eac0 f9410260 f9403801 aa1303e0 d63f0020 14000005
[   12.821130] eccc  11000694 91060000 6b02029f 54fffb81 b983fa61 f00049a0 f940e000 8b000020
[   12.821875] ecec  97cd837d aa0003e1 91104260 97cd8c4e 35fff400 d538d081 f9423260 8b010000
[   12.822620] ed0c  885f7c03 11000463 88027c03 35ffffa2 17ffff98 f941e276 52800040 9bb75a96
[   12.823368]
[   12.823368] SP: 0xffffffc0f7f2ad70:
[   12.823801] ad70  0989f000 ffffff80 f1d93280 ffffffc0 00000004 00000000 00000180 00000000
[   12.824550] ad90  ffffffff 00000000 00000200 dead0000 00000000 00000000 f7f2adf0 ffffffc0
[   12.825295] adb0  08d9ecac ffffff80 f7f2adf0 ffffffc0 08d9ecac ffffff80 00000145 00000000
[   12.826040] add0  096d5000 ffffff80 fffb9dc1 00000000 00000000 00000080 0000000f 00000000
[   12.826785] adf0  f7f2ae40 ffffffc0 081013bc ffffff80 f7f2bb80 ffffffc0 098a0000 ffffff80
[   12.827533] ae10  00000100 00000000 08d9eb0c ffffff80 f2552410 ffffffc0 f2552000 ffffffc0
[   12.828279] ae30  08d9eb0c ffffff80 f2552000 ffffffc0 f7f2ae80 ffffffc0 081016dc ffffff80
[   12.829023] ae50  f7f2bb80 ffffffc0 f2552410 ffffffc0 00000002 00000000 096d5000 ffffff80
[   12.829769]
[   12.829769] X2: 0xffffffc0f7f2e2c8:
[   12.830201] e2c8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.830946] e2e8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.831687] e308  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.832433] e328  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.833181] e348  f7f2bb40 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[   12.833926] e368  00000001 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[   12.834668] e388  f7f2e388 ffffffc0 f7f2e388 ffffffc0 00000000 00000000 00000000 00000000
[   12.835415] e3a8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.836162]
[   12.836162] X6: 0xffffff80098f48b8:
[   12.836595] 48b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.837343] 48d8  00000000 00000000 00000001 00000000 30303020 32303330 34333730 34205d33
[   12.838088] 48f8  20386638 382e3231 36313633 58205d32 30203a36 66666678 38666666 38393030
[   12.838833] 4918  62383466 300a3a38 39643830 63616365 70205d3e 74617473 30203a65 30303030
[   12.839576] 4938  0a353431 30303030 656e770a 70635f72 30203a75 3030300a 6c6c750a 625b2029
[   12.840322] 4958  30207375 66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e
[   12.841067] 4978  7020676e 7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e
[   12.841814] 4998  4c422b20 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29
[   12.842560]
[   12.842560] X10: 0xffffff80098f486f:
[   12.843000] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.843745] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.844490] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.845236] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   12.845984] 48ec  382e3231 38393531 34205d34 20636538 382e3231 36353234 58205d30 203a3031
[   12.846729] 490c  66667830 66666666 39303038 38346638 0a3a6636 39643830 63616365 70205d3e
[   12.847474] 492c  74617473 30203a65 30303030 0a353431 30303030 656e770a 70635f72 30203a75
[   12.848219] 494c  3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   12.848967] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   12.849713]
[   12.849713] X13: 0xffffff80898f4867:
[   12.850153] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   12.850899] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   12.851643] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.852389] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.853133] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.853879] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   12.854625] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   12.855374] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   12.856117] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   12.856866]
[   12.856866] X16: 0xffffff80081edddc:
[   12.857306] dddc  34fff777 91020260 97fffc1f 17ffffb8 f9403720 b4fffa40 aa1903e0 94073e42
[   12.858053] ddfc  17ffffcf 52800017 17fffff4 12800034 17ffffaf 12800014 17ffffb3 128002b4
[   12.858797] de1c  17ffffb1 12800114 17ffffb3 12800114 17fffe82 71000aff 54fff420 71000eff
[   12.859542] de3c  54fff640 12800214 710006ff 54ffef40 17fffea8 b5fff3f6 f94057a0 17fffe6d
[   12.860289] de5c  a9b57bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0103fa
[   12.861036] de7c  aa0203f8 aa0003f4 aa0303f3 aa1e03e0 d503201f 51000701 321f67e0 6b00003f
[   12.861779] de9c  54001708 d5384101 937c7f00 f9400422 aa1a03e1 ab000021 fa423022 9a9f87e3
[   12.862524] debc  b4001643 2a1403e0 97ff6a02 f90037a0 f27ef415 540015e0 f94016a1 f0006e60
[   12.863268]
[   12.863268] X19: 0xffffffc0f2551f80:
[   12.863709] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.864454] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.865200] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.865948] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.866693] 2000  30687465 00000000 00000000 00000000 00000000 00000000 f2488788 ffffffc0
[   12.867438] 2020  00000000 00000000 00000000 00000000 00000000 00000000 09be0000 ffffff80
[   12.868183] 2040  00000018 00000000 00000003 00000000 0986c7d0 ffffff80 f241c050 ffffffc0
[   12.868931] 2060  f2552a58 ffffffc0 f2552a58 ffffffc0 f2552070 ffffffc0 f2552070 ffffffc0
[   12.869678]
[   12.869678] X21: 0xffffffc0f2552360:
[   12.870118] 2360  f2552358 ffffffc0 ffffffff 0000ffff 00000000 00000000 00000000 00000000
[   12.870863] 2380  00000000 00000000 00000000 00000000 00000000 00000000 f2488810 ffffffc0
[   12.871608] 23a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.872355] 23c0  f1d93200 ffffffc0 00000001 00000001 ef5d0400 ffffffc0 000003e8 00000000
[   12.873102] 23e0  00020001 dead4ead 00000004 00000000 f328b600 ffffffc0 00001388 00000000
[   12.873847] 2400  00000000 00000000 fffb7634 00000000 00000200 dead0000 00000000 00000000
[   12.874592] 2420  fffb9dc0 00000000 08d9eb0c ffffff80 f2552000 ffffffc0 00000004 ffffffff
[   12.875337] 2440  ffffffff 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.876086]
[   12.876086] X22: 0xffffff800989ef80:
[   12.876526] ef80  095fb674 ffffff80 00000000 00000000 f24a5de0 ffffffc0 f24a5d80 ffffffc0
[   12.877271] efa0  0814848c ffffff80 09227288 ffffff80 08f69988 ffffff80 08f69824 ffffff80
[   12.878017] efc0  08148724 ffffff80 095fb504 ffffff80 00000000 00000000 f24a5f60 ffffffc0
[   12.878763] efe0  f24a5e10 ffffffc0 0814848c ffffff80 09227288 ffffff80 08f67204 ffffff80
[   12.879508] f000  08f65ba4 ffffff80 08148724 ffffff80 095fb440 ffffff80 00000000 00000000
[   12.880254] f020  f24a6030 ffffffc0 f24a5f90 ffffffc0 0814848c ffffff80 09227288 ffffff80
[   12.880998] f040  08f67150 ffffff80 08f65abc ffffff80 08148724 ffffff80 095fda18 ffffff80
[   12.881743] f060  00000000 00000000 f24a60f0 ffffffc0 f24a6060 ffffffc0 0814848c ffffff80
[   12.882488]
[   12.882488] X23: 0xffffffc0f1d93200:
[   12.882929] 3200  f2552000 ffffffc0 ef5d0400 ffffffc0 ef5d0400 ffffffc0 f1e1ffc0 ffffffc0
[   12.883676] 3220  f1e1a780 ffffffc0 f1e1a598 ffffffc0 f1e1a7a8 ffffffc0 f1e1a780 ffffffc0
[   12.884423] 3240  0986ef70 ffffff80 f1e24528 ffffffc0 00000001 00000007 00000000 00000000
[   12.885171] 3260  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.885917] 3280  000b000b dead4ead ffffffff 00000000 ffffffff ffffffff ffffffff 00000000
[   12.886662] 32a0  fffb7d86 00000000 00000001 00000000 00000006 00000000 00000000 00000000
[   12.887407] 32c0  00000439 00000408 0000005a 00000000 00000000 00000000 00000000 00000000
[   12.888153] 32e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.888903]
[   12.888903] X29: 0xffffffc0f7f2ad70:
[   12.889343] ad70  0989f000 ffffff80 f1d93280 ffffffc0 00000004 00000000 00000180 00000000
[   12.890089] ad90  ffffffff 00000000 00000200 dead0000 00000000 00000000 f7f2adf0 ffffffc0
[   12.890833] adb0  08d9ecac ffffff80 f7f2adf0 ffffffc0 08d9ecac ffffff80 00000145 00000000
[   12.891578] add0  096d5000 ffffff80 fffb9dc1 00000000 00000000 00000080 0000000f 00000000
[   12.892321] adf0  f7f2ae40 ffffffc0 081013bc ffffff80 f7f2bb80 ffffffc0 098a0000 ffffff80
[   12.893067] ae10  00000100 00000000 08d9eb0c ffffff80 f2552410 ffffffc0 f2552000 ffffffc0
[   12.893815] ae30  08d9eb0c ffffff80 f2552000 ffffffc0 f7f2ae80 ffffffc0 081016dc ffffff80
[   12.894560] ae50  f7f2bb80 ffffffc0 f2552410 ffffffc0 00000002 00000000 096d5000 ffffff80
[   12.895305]
[   12.895438] ---[ end trace 7582a5e8f3421942 ]---
[   12.895841] Call trace:
[   12.896057] Exception stack(0xffffffc0f7f2ac10 to 0xffffffc0f7f2ad40)
[   12.896618] ac00:                                   ffffffc0f2552000 0000008000000000
[   12.897300] ac20: ffffffc0f7f2adf0 ffffff8008d9ecac 0000000000000145 000000060001a23c
[   12.897980] ac40: 0000000000000000 0000000100000000 ffffffc0f7f2acf0 ffffff80080edb74
[   12.898660] ac60: ffffffc0f7f2ad70 ffffff80094fb83a ffffffc0f25523e0 ffffff800989f000
[   12.899342] ac80: ffffffc0f1d93280 0000000000000004 0000000000000180 00000000ffffffff
[   12.900023] aca0: dead000000000200 0000000000000000 0000000000000001 ffffff8009692000
[   12.900705] acc0: 0000000000000041 00000040ee895000 ffffffc0f7f2e348 0000000000000000
[   12.901386] ace0: 0000000000000000 0000000000000000 ffffff80098f4938 736e617274203a29
[   12.902067] ad00: 756575712074696d 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   12.902748] ad20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   12.903432] [<ffffff8008d9ecac>] dev_watchdog+0x1a0/0x238
[   12.903905] [<ffffff80081013bc>] call_timer_fn+0x9c/0x158
[   12.904376] [<ffffff80081016dc>] run_timer_softirq+0x238/0x244
[   12.904886] [<ffffff8008081180>] __do_softirq+0x250/0x300
[   12.905358] [<ffffff800809ffa0>] irq_exit+0x8c/0xd8
[   12.905785] [<ffffff80080eeb44>] __handle_domain_irq+0x84/0xb8
[   12.906292] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   12.906769] Exception stack(0xffffffc0f32a7da0 to 0xffffffc0f32a7ed0)
[   12.907331] 7da0: ffffffc0f7f31180 00000040ee895000 ffffffc0f7f31180 ffffffc0f32a7eb0
[   12.908012] 7dc0: 00ffffffffffffff 0000000018661874 0000000000005ff8 0000000000000000
[   12.908693] 7de0: ffffffc0f32a7f50 0000000000000000 00000000000009a0 0000000000000474
[   12.909375] 7e00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   12.910056] 7e20: ffffff80081ede5c 0000000000000000 0000000000000000 00000002f537a858
[   12.910737] 7e40: 0000000000000000 ffffffc0f1f7a400 0000000000000000 ffffff80098a0ce0
[   12.911419] 7e60: 0000000000000000 00000002f528758e ffffff800983def0 0000000001193244
[   12.912100] 7e80: 0000000000000000 ffffffc0f32a7ed0 ffffff8008c43ccc ffffffc0f32a7ed0
[   12.912781] 7ea0: ffffff8008c43d00 0000000060000145 ffffffc0f32a7ed0 ffffff8008c43ccc
[   12.913463] 7ec0: ffffffffffffffff 0000000000000000
[   12.913888] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   12.914317] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   12.914841] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   12.915305] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   12.915760] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   12.916270] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   12.916816] [<0000000001193188>] 0x1193188
[   24.156984] Watchdog detected hard LOCKUP on cpu 0
[   24.157403] ------------[ cut here ]------------
[   24.157824] WARNING: at kernel/watchdog.c:352
[   24.158205] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[   24.158989]
[   24.159125] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G        W       4.4.180 #1
[   24.159754] Hardware name: Pine64 RockPro64 (DT)
[   24.160157] task: ffffffc0f328c380 task.stack: ffffffc0f32a8000
[   24.160683] PC is at watchdog_timer_fn+0x190/0x2e8
[   24.161103] LR is at watchdog_timer_fn+0x190/0x2e8
[   24.161520] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[   24.162163] sp : ffffffc0f7f3fdf0
[   24.162453] x29: ffffffc0f7f3fdf0 x28: 0000000000000000
[   24.162923] x27: ffffff80096d7720 x26: ffffff8009698260
[   24.163393] x25: ffffffc0f7f42278 x24: ffffffc0f32abda0
[   24.163862] x23: 0000000000000000 x22: 0000000000000012
[   24.164331] x21: ffffff80096d6000 x20: ffffff80096982d8
[   24.164799] x19: ffffff8009698000 x18: 0000000000000005
[   24.165268] x17: 0000000000000000 x16: ffffff800811d6d8
[   24.165737] x15: 0000000000000000 x14: 000000000000000a
[   24.166205] x13: ffffff80898f48e7 x12: 0000000000000030
[   24.166674] x11: 0000000000000006 x10: ffffff80098f48ef
[   24.167143] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[   24.167612] x7 : 6574636574656420 x6 : ffffff80098f491d
[   24.168081] x5 : 00000000fffffffe x4 : 0000000000000002
[   24.168549] x3 : 00000040ee8aa000 x2 : 00000040ee8aa000
[   24.169018] x1 : 0000000000000005 x0 : 0000000000000026
[   24.169488]
[   24.169488] PC: 0xffffff800812c6b8:
[   24.169921] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.170669] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.171415] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.172160] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.172905] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.173651] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.174400] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.175144] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.175890]
[   24.175890] LR: 0xffffff800812c6b8:
[   24.176322] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.177066] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.177811] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.178555] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.179303] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.180050] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.180793] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.181538] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.182284]
[   24.182284] SP: 0xffffffc0f7f3fd70:
[   24.182716] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.183461] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.184207] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.184955] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.185700] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.186445] fe10  9a44408e 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000007 00000000
[   24.187190] fe30  098a07b8 ffffff80 9a44408e 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.187932] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.188679]
[   24.188679] X6: 0xffffff80098f489d:
[   24.189111] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.189859] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.190604] 48dc  00000000 00000001 00000000 30303020 32303330 30363030 34205d34 20636438
[   24.191349] 48fc  312e3432 37363838 58205d39 30203a36 66666678 38666666 38393030 39383466
[   24.192092] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[   24.192838] 493c  63636333 656e770a 70635f72 30203a75 3030300a 6c6c750a 625b2029 30207375
[   24.193582] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[   24.194327] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[   24.195075] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[   24.195821]
[   24.195821] X10: 0xffffff80098f486f:
[   24.196261] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197005] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197750] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.198495] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   24.199243] 48ec  312e3432 34323932 34205d33 20636538 312e3432 32383539 58205d31 203a3031
[   24.199989] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[   24.200734] 492c  74617473 36203a65 30303030 0a356331 63636333 656e770a 70635f72 30203a75
[   24.201480] 494c  3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   24.202228] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   24.202976]
[   24.202976] X13: 0xffffff80898f4867:
[   24.203416] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204166] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204912] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.205654] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206394] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207139] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207885] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   24.208630] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   24.209372] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   24.210119]
[   24.210119] X16: 0xffffff800811d658:
[   24.210559] d658  b50000f3 f90002bf 2a1303e0 f94013f5 a94153f3 a8c47bfd d65f03c0 d2800200
[   24.211307] d678  97ffff4e aa0003f4 b5000060 128001b3 17fffff6 aa1303e1 9100c3a0 97fffe03
[   24.212050] d698  2a0003f3 35ffff40 d5384100 f9400401 aa1403e0 b1004000 fa413002 9a9f87e2
[   24.212795] d6b8  b4fffe62 d2800202 9100c3a1 aa1403e0 940c15ae b5fffdc0 f90002b4 17ffffe3
[   24.213541] d6d8  a9bb7bfd 910003fd a90153f3 a9025bf5 aa0003f3 aa0103f4 aa1e03e0 d503201f
[   24.214289] d6f8  aa1303e1 9100c3a0 97fffde8 340000e0 928001b3 aa1303e0 a94153f3 a9425bf5
[   24.215034] d718  a8c57bfd d65f03c0 f9401ba0 b7f804c0 f9401fa1 d2993fe0 f2a77340 eb00003f
[   24.215779] d738  54000428 d5384115 92800000 f94006b6 f90006a0 d503201f f100029f 910103a1
[   24.216524]
[   24.216524] X19: 0xffffff8009697f80:
[   24.216965] 7f80  ******** ******** ******** ******** ******** ******** ******** ********
[   24.217709] 7fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218451] 7fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219198] 7fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219945] 8000  ******** ******** ******** ******** ******** ******** ******** ********
[   24.220691] 8020  ******** ******** ******** ******** ******** ******** ******** ********
[   24.221435] 8040  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222179] 8060  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222923]
[   24.222923] X20: 0xffffff8009698258:
[   24.223364] 8258  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224107] 8278  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224851] 8298  ******** ******** ******** ******** ******** ******** ******** ********
[   24.225600] 82b8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226343] 82d8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227090] 82f8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227834] 8318  ******** ******** ******** ******** ******** ******** ******** ********
[   24.228579] 8338  ******** ******** ******** ******** ******** ******** ******** ********
[   24.229326]
[   24.229326] X21: 0xffffff80096d5f80:
[   24.229767] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.230515] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231260] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232006] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232751] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.233495] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234240] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234985] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.235727]
[   24.235727] X24: 0xffffffc0f32abd20:
[   24.236168] bd20  00000000 00000000 f328c380 ffffffc0 000001c0 00000000 08c6cdb0 ffffff80
[   24.236914] bd40  00000002 00000000 080913c4 ffffff80 f32abd60 ffffffc0 080914b8 ffffff80
[   24.237662] bd60  f32abe70 ffffffc0 08c6d42c ffffff80 f32abdb0 ffffffc0 08cee258 ffffff80
[   24.238407] bd80  f2537210 ffffffc0 f2536e10 ffffffc0 f32abdb0 ffffffc0 08cee2a8 ffffff80
[   24.239152] bda0  f7f46180 ffffffc0 ee8aa000 00000040 f7f46180 ffffffc0 f32abeb0 ffffffc0
[   24.239896] bdc0  ffffffff 00ffffff 28a5e2b4 00000000 0000b8b6 00000000 00000000 00000000
[   24.240644] bde0  f32abf50 ffffffc0 00000000 00000000 000009a0 00000000 00000474 00000000
[   24.241391] be00  0000011d 00000000 00000001 00000003 00000004 00000000 00000000 00000000
[   24.242136]
[   24.242136] X25: 0xffffffc0f7f421f8:
[   24.242577] 21f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7f42210 ffffffc0
[   24.243322] 2218  f7f42210 ffffffc0 f7f42220 ffffffc0 f7f42220 ffffffc0 0812b194 ffffff80
[   24.244067] 2238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[   24.244813] 2258  00000001 00000000 00000006 00000000 00000005 00000000 f3326c00 ffffffc0
[   24.245561] 2278  f7f42278 ffffffc0 f7f420e8 ffffffc0 00000000 00000000 9a443dc0 00000005
[   24.246306] 2298  9a443dc0 00000005 0812c5a8 ffffff80 f7f41c80 ffffffc0 00000000 0000001f
[   24.247051] 22b8  0812c57c ffffff80 63746177 676f6468 0000352f 00000000 00000006 00000000
[   24.247796] 22d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   24.248544]
[   24.248544] X26: 0xffffff80096981e0:
[   24.248985] 81e0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249732] 8200  ******** ******** ******** ******** ******** ******** ******** ********
[   24.250477] 8220  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251222] 8240  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251967] 8260  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252715] 8280  ******** ******** ******** ******** ******** ******** ******** ********
[   24.253456] 82a0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254200] 82c0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254944]
[   24.254944] X27: 0xffffff80096d76a0:
[   24.255385] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51440 ffffffc0
[   24.256129] 76c0  00000015 00000000 f7f51400 ffffffc0 00000001 00000006 00000060 00000000
[   24.256875] 76e0  00015000 00001000 00000001 00000000 f7f51480 ffffffc0 f7f514c0 ffffffc0
[   24.257618] 7700  00000000 00000005 00000010 00000000 f7f51300 ffffffc0 f7ed3000 ffffffc0
[   24.258363] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[   24.259108] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[   24.259853] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[   24.260601] 7780  0001e28c 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[   24.261347]
[   24.261347] X29: 0xffffffc0f7f3fd70:
[   24.261787] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.262532] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.263275] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.264021] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.264769] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.265514] fe10  9a44408e 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000007 00000000
[   24.266259] fe30  098a07b8 ffffff80 9a44408e 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.267004] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.267752]
[   24.267886] ---[ end trace 7582a5e8f3421943 ]---
[   24.268288] Call trace:
[   24.268506] Exception stack(0xffffffc0f7f3fc10 to 0xffffffc0f7f3fd40)
[   24.269067] fc00:                                   ffffff8009698000 0000008000000000
[   24.269749] fc20: ffffffc0f7f3fdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[   24.270430] fc40: 0000000000000026 0000000000000000 ffffffc0f7f3fcf0 ffffff80080edb74
[   24.271111] fc60: ffffffc0f7f3fd70 ffffff800937898b ffffff80096d6000 0000000000000012
[   24.271793] fc80: 0000000000000000 ffffffc0f32abda0 ffffffc0f7f42278 ffffff8009698260
[   24.272474] fca0: ffffff80096d7720 0000000000000000 0000000000000001 ffffff8009692000
[   24.273156] fcc0: 0000000000000026 0000000000000005 00000040ee8aa000 00000040ee8aa000
[   24.273837] fce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[   24.274518] fd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   24.275199] fd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   24.275883] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[   24.276394] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[   24.276925] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[   24.277428] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[   24.277969] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[   24.278515] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[   24.279017] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[   24.279527] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   24.280006] Exception stack(0xffffffc0f32abda0 to 0xffffffc0f32abed0)
[   24.280567] bda0: ffffffc0f7f46180 00000040ee8aa000 ffffffc0f7f46180 ffffffc0f32abeb0
[   24.281248] bdc0: 00ffffffffffffff 0000000028a5e2b4 000000000000b8b6 0000000000000000
[   24.281930] bde0: ffffffc0f32abf50 0000000000000000 00000000000009a0 0000000000000474
[   24.282612] be00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   24.283293] be20: ffffff800811d6d8 0000000000000000 0000000000000000 000000059a443e47
[   24.283973] be40: 0000000000000000 ffffffc0f1f7a600 0000000000000000 ffffff80098a0ce0
[   24.284654] be60: 0000000000000000 000000059a350ca1 ffffff800983def0 0000000001193244
[   24.285336] be80: 0000000000000000 ffffffc0f32abed0 ffffff8008c43ccc ffffffc0f32abed0
[   24.286017] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f32abed0 ffffff8008c43ccc
[   24.286698] bec0: ffffffffffffffff 0000000000000000
[   24.287123] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   24.287552] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   24.288075] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   24.288539] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   24.288994] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   24.289503] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   24.290048] [<0000000001193188>] 0x1193188
LSI SAS3082E-R - by kram0000 - 11-01-2019, 03:05 PM
RE: LSI SAS3082E-R - by kram0000 - 11-02-2019, 11:54 AM
RE: LSI SAS3082E-R - by t4_4t - 11-04-2019, 01:52 AM
RE: LSI SAS3082E-R - by kram0000 - 11-04-2019, 05:57 PM
RE: LSI SAS3082E-R - by t4_4t - 11-04-2019, 08:36 PM
RE: LSI SAS3082E-R - by kram0000 - 11-05-2019, 11:26 AM
RE: LSI SAS3082E-R - by kram0000 - 11-05-2019, 12:27 PM
RE: LSI SAS3082E-R - by t4_4t - 11-05-2019, 08:34 PM
RE: LSI SAS3082E-R - by kram0000 - 11-14-2019, 12:21 AM
RE: LSI SAS3082E-R - by AndrewC78 - 05-10-2020, 05:40 AM
RE: LSI SAS3082E-R - by kram0000 - 09-13-2020, 08:59 PM
