generall network interface issues
(05-09-2016, 04:28 AM)tkaiser Wrote:
(05-09-2016, 04:16 AM)Sandman01 Wrote: same situation.
Maybe still same issue: powering problems. Since people are busy feeding bug trackers that work like a trash can (you throw things in and nothing will happen) or following silly workaround paths instead of following the advices given here to try to nail the problems down no progress has been made since weeks.
Some of the devs suspect that GbE related connection problems are related to underpower,inf situations, users were asked to ensure providing stable 5V to their board and report back but zero feedback so far. Since you get boot loops with connected WiFi you could also try to connect something power hungry to the USB ports. If the board doesn't boot up you know what to blame: crappy Micro USB used for DC-IN.
In that case try powering through the Euler connector and report back whether boot loops and Ethernet problems are gone. BTW: Self assigning an address in the 169.254.0.0/16 range is quite normal if no DHCP server could be reached.
nail the problem down is that what I like.
I testet now with 5 different supplys always with the same behavior.
Also my preferred supply at the moment is a power bank connected at the Rpi connector (will try euler also) that supplies 3,2Amps max.
I belive the issue is on my side, and I'm very happy that you try to help me.
However my issue is a bit strange because I know from the other threads that in general it should work out of the box (100MBit connection would be enough for testing)
regards Mario
.txt   ubuntu_longsleep.txt (Size: 40.44 KB / Downloads: 357)
generall network interface issues - by Sandman01 - 04-28-2016, 04:31 AM
RE: generall network interface issues - by Sandman01 - 05-09-2016, 12:56 PM
Question Jerky wired network ale 1 2,328 04-11-2022, 03:40 AM
Last Post: ale
  First time user experiencing weird keyboard issues kendew 5 6,147 06-19-2021, 08:14 AM
Last Post: rotwang
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 3,066 04-26-2021, 06:03 AM
Last Post: slowcamp
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,887 02-02-2021, 12:13 AM
Last Post: PineSupporter
  WiFi issues Pinebook Pro sunnystormy 6 9,003 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 10,777 06-13-2019, 04:25 PM
Last Post: evilbunny
  Network issues, possibly not booting? [Solved] Ryanteck 3 5,284 06-17-2017, 11:01 AM
Last Post: xalius
Thumbs Down Issues with Android mliebski 0 1,996 07-01-2016, 11:14 AM
Last Post: mliebski
  Performance issues chrwei 6 7,422 04-27-2016, 07:17 AM
Last Post: chrwei
