Tested PCIe cards and output
Hi! Probably, your card requires BIOS support which is impossible with this SBC. For the chip your card used there should be Marvell BIOS support, like I see in different product user manual.
[Image: attachment.php?aid=1441]
The cards which doesn't use dedicated BIOS support should work.
Also if you have spare hardware, you can try to insert the card into PCIe slot while the SBC is running, make a hotplug. If the hardware will not blow-up, probably you will got more information in kernel log.
.png   Screenshot from 2019-10-17 11-48-25.png (Size: 118.14 KB / Downloads: 1,037)
Tested PCIe cards and output - by kram0000 - 10-16-2019, 08:23 PM
RE: Tested PCIe cards and output - by Nikolay_Po - 10-17-2019, 02:56 AM
RE: Tested PCIe cards and output - by kram0000 - 10-21-2019, 02:38 PM
RE: Tested PCIe cards and output - by Nikolay_Po - 10-22-2019, 08:38 AM
RE: Tested PCIe cards and output - by kram0000 - 10-22-2019, 03:55 PM
RE: Tested PCIe cards and output - by xalius - 10-24-2019, 01:17 PM
  Compatible PCIe Sata Controller spacebricker 1 1,501 02-06-2023, 10:03 AM
Last Post: diizzy
  PCIe bifurcation support (on RK3399) Arn 1 1,248 11-28-2022, 05:12 PM
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,384 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 4,840 02-17-2021, 11:35 AM
Last Post: dml-pc
  Nvidia GPU on PCIe User 18962 4 4,751 12-22-2020, 02:54 PM
Last Post: amiraeva
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 2,846 10-20-2020, 12:22 PM
Last Post: xmixahlx
  RockPro64 pcie Gpu Davidos 8 15,037 07-14-2020, 05:11 PM
Last Post: ProDigit
  PCIe failure odhinnhrafn 11 12,089 03-16-2020, 08:39 AM
Last Post: odhinnhrafn
Question Can we add PCIE hub 1 to many pcie card seaurchin 1 3,038 11-25-2019, 11:08 AM
  No boot with Supermicro AOC-SASLP-MV8 (serial output) kram0000 0 1,736 10-22-2019, 04:00 PM
Last Post: kram0000
