Pine book Pro Speakers
#23
(11-04-2019, 08:42 AM)MrTester Wrote:
(11-04-2019, 07:33 AM)zaius Wrote:
(11-03-2019, 10:25 PM)MrTester Wrote: I have included photos of my work, my preferred choice was athletic tape (woven fabric tape, with high adhesive properties).
Have you considered trying friction tape?  It's cotton cloth impregnated with rubber. Once used as electrical tape, it has good adhesion, it's non-conductive, and very durable.  It's generally 15 mil, so it might be thicker without being too thick.
I do not have access to any Friction Tape at home or at work currently. I would agree this may be the safest, and most functional option.
(11-04-2019, 07:04 AM)rick1959 Wrote:
(11-03-2019, 10:25 PM)MrTester Wrote: Greetings PBP friends,
Tonight I decided to dig inside and see what mechanical/ acoustical improvements I could make to the PBP speaker system.
Background: Initially when working on my PBP, I noticed when playing audio, the playback was extremely harsh on the ears and a significant amount of resonance in the palm rest (back side of the speakers) My main goal was to observe and find some mechanical isolation solution to improve audio.
Observations: After opening my PBP, I found the following, A simple speaker, isolated from the metal bottom of the laptop (and speaker grill/opening ) by an adhesive foam surround. The back of the speaker (magnet side) is directly adhered to the plastic palm rests, located in place by molded frame apart of the palm rest.
My initial assessment was that a significant amount of energy was being transferred from the speaker magnet directly into the palm rests, resulting in physical resonance and contributing to the observed acoustical resonance.  Considering the space as tight manufacturing tolerances, any mechanical isolation solution would need to be minimal thickness. With the above comment considering a MFG change could be considered, The cost of such options was in consideration.
I tested Duct tape, Electrical tape, and athletic tape. My intention was to cut just enough tape, to fit behind the speaker, and isolate it from the palm rest. All produced significant reduction in physical energy transfer into the palm rest. The acoustical improvement is reasonable in my opinion, I would like others to test if this is a significant enough of a improvement.
That's excellent!!
And sounds, forgive the pun, that the tape may be what relieves (absorbs?) the buzziness?
Clearer high level volume? Clearer in general?
Here's my thought, unsolicited: How about a drop of rubber cement on the magnet, sufficient to spread wide enough to cover the whole circular area of the magnet? Just enough to insulate the magnet.....
I'm not brave enough, nor have the time to try it right now. However, what do you think? :-)
Its not a 100% catch all to all audio artifacts, I would like to see if I could apply some native equalization, in addition to the fix. The main concern to isolate most of the energy transfer from the magnet to the palm rest body was my goal. This did improve some of the vibration, We are far from a nice foam filled speaker box, but much closer.
A dab of RTV silicone or rubber cement would also potentially be cost possible, and easy to transfer into the manufacturing floor.
With this setup, anyone would be unreasonable to think symphonic quality sound would come from it. Good, functional sound at a reasonable volume, ok....
And your thoughtful, measured approach seems to be getting good results. Likely reaching the cost/benefit pretty quickly.
Right now, I'm inclined to use a Bluetooth setup (earbuds or speaker) to have higher fidelity sound. That, I've found, is a clearly reasonable way to achieve higher quality sound. No screwdriver required!! :-)
And the search continues... :-)
Pine book Pro Speakers - by bcnaz - 10-13-2019, 11:47 PM
RE: Pine book Pro Speakers - by PakoSt - 10-14-2019, 02:50 AM
RE: Pine book Pro Speakers - by bcnaz - 10-14-2019, 05:36 AM
RE: Pine book Pro Speakers - by bcnaz - 10-17-2019, 08:21 PM
RE: Pine book Pro Speakers - by User 6582 - 10-18-2019, 08:11 PM
RE: Pine book Pro Speakers - by bcnaz - 10-19-2019, 07:59 AM
RE: Pine book Pro Speakers - by User 6582 - 10-19-2019, 09:58 AM
RE: Pine book Pro Speakers - by evilbunny - 10-19-2019, 03:30 PM
RE: Pine book Pro Speakers - by bcnaz - 10-19-2019, 05:07 PM
RE: Pine book Pro Speakers - by danielt - 10-20-2019, 12:28 PM
RE: Pine book Pro Speakers - by User 6582 - 10-20-2019, 07:22 PM
RE: Pine book Pro Speakers - by bcnaz - 10-20-2019, 07:39 PM
RE: Pine book Pro Speakers - by User 6582 - 10-20-2019, 08:45 PM
RE: Pine book Pro Speakers - by Watercourse - 10-21-2019, 12:19 PM
RE: Pine book Pro Speakers - by bcnaz - 10-21-2019, 05:15 PM
RE: Pine book Pro Speakers - by MrTester - 10-31-2019, 04:44 PM
RE: Pine book Pro Speakers - by tllim - 11-02-2019, 10:37 PM
RE: Pine book Pro Speakers - by MrTester - 11-03-2019, 10:25 PM
RE: Pine book Pro Speakers - by User 6582 - 11-04-2019, 07:04 AM
RE: Pine book Pro Speakers - by zaius - 11-04-2019, 07:33 AM
RE: Pine book Pro Speakers - by MrTester - 11-04-2019, 08:42 AM
RE: Pine book Pro Speakers - by User 6582 - 11-04-2019, 09:34 AM
RE: Pine book Pro Speakers - by Watercourse - 11-04-2019, 08:13 AM
RE: Pine book Pro Speakers - by MrTester - 11-06-2019, 08:37 AM
RE: Pine book Pro Speakers - by tophneal - 11-06-2019, 08:58 AM
RE: Pine book Pro Speakers - by TDC_PBP - 05-07-2020, 03:42 PM
RE: Pine book Pro Speakers - by tllim - 05-09-2020, 11:23 PM
RE: Pine book Pro Speakers - by TDC_PBP - 05-20-2020, 07:05 AM
  Are you interested in a new design of Pine laptop? CleanEnvironment 2 4,559 11-12-2025, 02:33 PM
Last Post: WEF
  Pine Book Pro Charging Problems balin 7 13,523 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  how to get rid of heavy distortion from the speakers? stozi 2 4,631 02-20-2022, 05:46 AM
Last Post: stozi
  Up-firing speakers!!! mamboman777 6 10,383 07-28-2021, 02:54 PM
Last Post: mamboman777
  If booted with headphones in, sound comes from them and speakers stozi 6 10,554 06-11-2021, 01:27 AM
Last Post: dsimic
  Pine Key + Backspace/Arrow Keys not registering tslight 3 7,650 06-13-2020, 11:31 PM
Last Post: xmixahlx
  A request to anyone with a Pinebook pro / other Pine device.. account3122 14 30,278 06-05-2020, 02:52 AM
Last Post: icecream95
  Issues connecting bluetooth headphones and speakers jamathis 2 6,310 12-01-2019, 11:21 AM
Last Post: jamathis
