12-09-2019, 01:31 PM
Debian Installer:
Supported Platforms:
"The multiplatform support in the arm64 Linux kernel may also allow running debian-installer on arm64 systems not explicitly listed above. So long as the kernel used by debian-installer has support for the target system's components, and a device-tree file for that target is available, a new target system may work just fine. In these cases, the installer can usually provide a working installation, and so long as UEFI is in use, it should be able to make the system bootable as well. If UEFI is not used you may also need to perform some manual configuration steps to make the system bootable."
https://www.debian.org/releases/stable/arm64/
Daily builds:
https://d-i.debian.org/daily-images/arm64/
Daily builds:
