Rockpro64 and stock arch linux
(01-02-2020, 09:25 AM)Yoast Wrote: @TaborFife, have you managed to get this working using an eMMC module instead of a SD card? I tried it, but it doesn't boot:
U-Boot TPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
Channel 1: LP
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to
U-Boot SPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57 +0100)
Trying to boot from MMC2
unable to select a mode
mmc_load_image_raw_sector: mmc block read error
Trying to boot from MMmmc_load_image_raw_sector: mmc block read error
Trying to boot mmc_load_image_raw_sector: mmc block read error
SPL: failed to rd ###
FATAL: read from port failed: Device not configured
Hi, I'm able to boot from eMMC using the latest ROOTFS tarball. The latest kernel update seems to have nuked my setup though.
Rockpro64 and stock arch linux - by TaborFife - 09-21-2019, 04:29 PM
RE: Rockpro64 and stock arch linux - by Yoast - 11-29-2019, 12:18 PM
RE: Rockpro64 and stock arch linux - by Yoast - 01-02-2020, 09:25 AM
RE: Rockpro64 and stock arch linux - by dragop - 01-07-2020, 03:12 PM
RE: Rockpro64 and stock arch linux - by Yoast - 01-13-2020, 03:15 PM
RE: Rockpro64 and stock arch linux - by dragop - 01-15-2020, 05:17 PM
RE: Rockpro64 and stock arch linux - by abdel - 01-08-2020, 03:06 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,607 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 137,097 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,077 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,294 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,764 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 3,937 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,680 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,454 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,771 05-21-2023, 11:34 PM
Last Post: shpark
