Rockchip RK3399 PCIe lanes only 2.5GTb/s?
Okay, I may be wrong, (it's rare, but happens :-). From my reading, it appears that the PCIe lane speed is 2.5GTb/s, (aka PCIe 1.x speed), verses 5GTb/s in 2.x. (That said, the chip seems to support the protocol updates in PCIe 2.1.)
So, anyone else read it that way?
Here is a reference;
http://opensource.rock-chips.com/images/...170420.pdf
Page 89
Quote:Signal data channel data rate maximum up to 2.5GTb/s, with 8b/10b form, the maximum data rate up to 250MB/s
Next line adds the following, (which implies all 4 lanes working together);
Quote:Work in full-duplex mode, maximum data rate up to 10GTb/s, which is 1GB/s
All that means, (if I've read that right), is any NVME drive will be limited by this change. Probably not an issue for 4 lane NVME drives. Though 2 lane NVME drives, (like that nice low power Western Digital Blue), might suffer a little. This will not stop me from using a NVME drive, though I might make more effort to find a 4 lane device that has reasonable power usage.
Also, (my original reason for the research), it appears that the 4 x PCIe lanes can not be bi-furcated into 2 x 2 PCIe lanes. All 4 must work together, as either 1/2/4 lanes. (So it DOES support 2 lane PCIe devices, like the afore mentions WD Blue NVME drive.)
Arwen Evenstar
Princess of Rivendale
Rockchip RK3399 PCIe lanes only 2.5GTb/s? - by Arwen - 08-24-2019, 05:02 PM
  Revisiting RK3399 LPDDR speeds Syonyk 1 1,363 01-02-2022, 10:03 AM
Last Post: Syonyk
  RK3399 - big.LITTLE core choice optimization lucserre 3 5,671 06-29-2020, 11:12 AM
Last Post: xmixahlx
  Memory clock speed: 800MHz vs 1600MHz? (NM, RK3399 won't run >800MHz DDR) Syonyk 4 7,047 06-26-2020, 07:22 PM
Last Post: Syonyk
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 10,690 12-19-2019, 05:15 AM
Last Post: ndp
  PCIe card success ? DrYak 0 1,897 11-12-2019, 01:16 PM
Last Post: DrYak
  PCIe Der Geist der Maschine 2 4,032 11-07-2019, 07:31 AM
Last Post: VoxUnius
