Charging via USB-C Port
Thanks for sharing.
But is it safe to use my Raspberry Pi 5.1V 3A power adapter to charge PBP?
The supplied adapter for PBP at 5V 3A takes a long time to charge PBP. And it's true that charging is even slower when I charge and use PBP at the same time.
So, if I were to use Baseus GaN 65W Fast USB Charger (Quick Charge 4.0 3.0 Type C PD Fast Charging 3 Port Portable Charger), will it help?
Charging via USB-C Port - by tyha - 08-22-2019, 11:51 PM
RE: Charging via USB-C Port - by kaylios - 08-23-2019, 02:56 AM
RE: Charging via USB-C Port - by Luke - 08-23-2019, 08:07 AM
RE: Charging via USB-C Port - by kaylios - 08-23-2019, 10:17 AM
RE: Charging via USB-C Port - by hdk - 11-26-2019, 07:54 AM
RE: Charging via USB-C Port - by Eggmonkey - 04-10-2020, 12:04 PM
RE: Charging via USB-C Port - by Eggmonkey - 04-10-2020, 01:25 PM
RE: Charging via USB-C Port - by Arwen - 04-11-2020, 04:20 PM
RE: Charging via USB-C Port - by MIchael - 04-11-2020, 07:38 PM
RE: Charging via USB-C Port - by iscmob - 07-19-2020, 08:30 PM
RE: Charging via USB-C Port - by MtnSk8 - 07-20-2020, 01:50 PM
RE: Charging via USB-C Port - by JaceAlvejetti - 07-20-2020, 06:25 PM
RE: Charging via USB-C Port - by iscmob - 07-21-2020, 08:28 PM
RE: Charging via USB-C Port - by JasonG-FR - 07-22-2020, 03:15 AM
RE: Charging via USB-C Port - by iscmob - 07-22-2020, 08:15 PM
Photo P{inebook Pro not charging Ome Ko 6 4,071 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 9,726 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  How are people finding the type-A USB 3.0 port? chris88233 1 1,817 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Very low battery (but charging) causes boot failures Phillip Bell 7 7,137 02-22-2022, 11:20 AM
  Fried the charger port and USB leapylee 1 2,523 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 6,122 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 3,920 05-01-2021, 04:13 AM
Last Post: gabeeg
  Serial port cable bsammon 17 33,337 03-04-2021, 10:00 AM
Last Post: mattpenn
  PineBookPro does not charging floppy_rofling 0 3,818 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 8,203 01-25-2021, 08:48 PM
Last Post: bchenlee609
