Throwing in the drawer
(04-28-2016, 11:04 AM)Luke Wrote:
(04-28-2016, 10:06 AM)tkaiser Wrote:
(04-28-2016, 09:59 AM)ThaPharmacist Wrote: I didn't know if the ubuntu img was working or not since I was having major issues just getting it to boot correctly with video.
The symptoms you described sound like 'insufficient power supply'. Micro USB encourages users to power the board wrong (using phone chargers or smart chargers that do not provide more than 500mA) and most USB cables are simply crap to power anything that needs a bit more than just a few mA since their resistance leads to voltage drops. Combine both and you've the reason for stability issues Smile
Yea, this is plausible. Even if you have a good psu (should be 2A+) the mirco usb wire can be the problem. I use  20 awg micro usb cables to power my Pine64s. The problem is that the Pine (unlike the Raspberry pi 3) doesn't give you an indication that it is not receiving enough power - so you may not even know that this is the issue. What PSU / cable are you using ? (usually says what awg it is on the cable)
I will take a look when I get home, but I own many Raspberry pis and have never had an issue. I also thought this could be it, but I did get Remix to boot then update, but then it just constantly rebooted itself over and over and over again. So I figured that cable was fine since it was powering
Throwing in the drawer - by ThaPharmacist - 04-26-2016, 01:39 PM
RE: Throwing in the drawer - by wymand - 04-26-2016, 02:06 PM
RE: Throwing in the drawer - by Luke - 04-27-2016, 08:48 AM
RE: Throwing in the drawer - by ThaPharmacist - 04-28-2016, 09:59 AM
RE: Throwing in the drawer - by tkaiser - 04-28-2016, 10:06 AM
RE: Throwing in the drawer - by Luke - 04-28-2016, 11:04 AM
RE: Throwing in the drawer - by ThaPharmacist - 04-28-2016, 02:34 PM
RE: Throwing in the drawer - by Luke - 04-29-2016, 06:33 AM
RE: Throwing in the drawer - by tkaiser - 04-29-2016, 06:38 AM
RE: Throwing in the drawer - by KE4JGX - 04-27-2016, 08:15 PM
RE: Throwing in the drawer - by Luke - 04-29-2016, 12:58 PM
RE: Throwing in the drawer - by nagmier - 04-29-2016, 01:26 PM
RE: Throwing in the drawer - by Luke - 04-30-2016, 04:11 PM
