WiFi/BT module not working on Android
(04-29-2016, 10:21 AM)tllim Wrote:
(04-29-2016, 09:18 AM)lesilva Wrote:
(04-28-2016, 01:54 PM)tllim Wrote:
(04-28-2016, 01:41 PM)lesilva Wrote: Anyone knows hot to fix this?
Have you turn on the Wifi switch at the setting page?
Of course! And the BT switch...
I check the sys info, the MAC address fields for both WIFI and BT are empty.
Seems like the module is not even recognized at all.
Please check whether the module has been plug in properly. If you can take a photo, i will confirmed. If the module is broken, I will send a replacement to you.
Here's the photo. As you can see 13, 14, 15, 16 are matching.
https://www.dropbox.com/s/f99chxfr6ddoa0...1.JPG?dl=0
RE: WiFi/BT module not working on Android - by lesilva - 04-29-2016, 10:49 AM
  USB adapter to eMMC module not recognized danril 0 1,324 11-25-2022, 04:16 AM
Last Post: danril
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,579 10-06-2022, 08:46 PM
Last Post: ihab
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,904 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 4,135 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Cannot charge and NO Wifi? jiapei100 3 5,468 06-27-2020, 02:11 PM
Last Post: jiapei100
Bug WiFi enabled but refuses to connect cardboardmaster 6 7,802 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 9,052 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 10,815 06-13-2019, 04:25 PM
Last Post: evilbunny
  Input not working after a forced shutdown dic1911 1 3,477 12-24-2018, 07:45 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 2,455 10-16-2018, 09:16 PM
Last Post: Tonny91
