I think I missed something simple.
(08-13-2019, 01:28 PM)gdb Wrote: Is there something I should be trying, or should I just RMA?
G
Are you using an microSD or an emmc? Have your tried different cards? Different OS's on those cards? Use a Linux distro or windows 10 and make a bootable from a downloaded image instead of the pine installer. See if the installer is the problem if the card is good. Check your hdmi cable too. See if any of that helps before you do a rma
I think I missed something simple. - by gdb - 08-04-2019, 01:29 PM
RE: I think I missed something simple. - by Luke - 08-04-2019, 01:53 PM
RE: I think I missed something simple. - by gdb - 08-04-2019, 04:37 PM
RE: I think I missed something simple. - by gdb - 08-13-2019, 01:28 PM
RE: I think I missed something simple. - by SBCraok - 08-15-2019, 11:22 AM
RE: I think I missed something simple. - by gdb - 08-23-2019, 05:42 PM
