RockPro64 not coming online after reboot
(08-03-2019, 07:49 AM)martinayotte Wrote: AmeriDroid maybe provided eMMC with pre-loaded with some unkown version of U-Boot, and as any Rockchip SoC start looking at eMMC before trying SDCard, this eMMC U-Boot has priority.
Yes they shipped the eMMC with some boot and OS on the chip. I overwrote them with the rockpro64 image though before booting on the board.
(08-03-2019, 07:49 AM)martinayotte Wrote: You can also copy the U-Boot sectors from SDCard to eMMC and boot without any SDCard inserted ...
I tried copying the entire working disk contents from the SD card to the (again blank) eMMC card; unfortunately I still get the same issue with only the eMMC card connected.
So, it appears that if there is any boot sector on the eMMC present, then the system hangs after `reboot` command. If there is an SD card present with boot sectors, and the eMMC is present with no boot sectors, then the issue does not happen. I have also written some filesystem to the eMMC card and mounted it at boot which was fine. Its just if the eMMC has boot sectors does the issue occur.
RE: RockPro64 not coming online after reboot - by imapc99 - 08-04-2019, 01:34 AM
  where to get debian 12 image for rockpro64? heocb 1 2,304 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 1,940 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 3,112 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 2,730 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 3,880 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 3,007 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 9,822 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 3,170 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 4,161 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 5,567 03-19-2023, 06:22 AM
Last Post: runyor
