Serial console
(11-03-2019, 10:21 PM).hmuller Wrote: Unclear at this point. I tested cable on the Debian desktop installed on microSD. Tomorrow I will look at the default installation on eMMC, and then at ayufan's bionic on microSD. Will let you know the results.
I've also been struggling to use the UART cable.
It appears that the PBP is detecting that the cable is attached and behaving differently when the cable is attached. In my case "differently" means the system won't boot correctly and locks up instead
It is not the presence of the jack that causes the system to hang. It only hangs when the adapter is attached to the USB host. I'm thinking of hacking together a custom cable try and stop the PBP detecting that someone is listening to the UART messages...
Serial console - by Thra11 - 07-25-2019, 08:19 AM
RE: Serial console - by Luke - 07-25-2019, 01:23 PM
RE: Serial console - by vincele - 08-22-2019, 03:32 AM
RE: Serial console - by hmuller - 11-01-2019, 09:53 PM
RE: Serial console - by belfastraven - 11-03-2019, 04:02 PM
RE: Serial console - by hmuller - 11-03-2019, 10:21 PM
RE: Serial console - by danielt - 11-05-2019, 09:36 AM
RE: Serial console - by danielt - 11-05-2019, 03:01 PM
RE: Serial console - by hmuller - 11-05-2019, 05:40 PM
RE: Serial console - by danielt - 11-06-2019, 03:40 AM
RE: Serial console - by Thra11 - 11-06-2019, 09:44 AM
RE: Serial console - by zaius - 11-06-2019, 02:35 PM
RE: Serial console - by Thra11 - 11-07-2019, 03:42 AM
RE: Serial console - by zaius - 11-07-2019, 06:39 AM
  Serial cable voltage rossk 1 2,699 12-13-2019, 02:36 PM
Last Post: zaius
  "Pinebook Serial Console" unreliable, inhibits boot, kills WiFi and SD Solra Bizna 9 12,168 12-06-2019, 09:53 PM
Last Post: Solra Bizna
  Pinebook serial console usage nemunaire 1 3,337 11-08-2019, 01:34 PM
Last Post: zaius
