08-12-2019, 12:34 PM
(This post was last modified: 08-12-2019, 12:36 PM by octavian.
Edit Reason: formatting
Hi, dazza5000,
Did you manage to write the compiled OS on your RockPro? I\'ve compiled mine from sources and I've just written a few partitions but now it boots directly into Maskrom.\
I haven't had any luck in the past with Android 7.1 compiled from sources either.
Not sure what I'm doing wrong but it drives me crazy, especially that I only need to modify something in the device tree (enable SPI bus).
Also when I'm deflating the SDK archive, tar tells me that there are some corrupted files, still I was able to compile it without any fatal errors.
I did use your Docker container for the build environment, it's a very big help, thank you!
Do you have any advice for me? I would greatly appreciate some help.
Thanks,
Octavian
Thanks,
Octavian
