Rock64Pro and 4K resolution
I just got a Rock64Pro and I installed DietPi (running MATE as the UI) on it.  Boots up just fine, but the video is standard HD (1920x1080).  I went into Control Centre and 4K resolution isn't even listed in the Resolution drop down.  Anyone have any suggestions on how I can get/enable 4K resolution?
The monitor is 4K, and Rock64 running DietPi operates in 4K mode.  I'm using the Rock64Pro version of DietPi.
Thanks,
Richard
Here's an update.  I was able to find an article online which provided me with the following commands to switch to 4K mode:
    xrandr --newmode "3840x2160" 338.75 3840 4080 4488 5136 2160 2163 2168 2200 -hsync +vsync
    xrandr --addmode HDMI-1 "3840x2160"
    xrandr --output HDMI-1 --mode "3840x2160"
When executed in Terminal, the system will switch to 4K resolution.  And under Armbian Ubuntu, if I add those lines to ~/.profile, Ubuntu boots to 4K resolution.  When I tried adding those lines to ~/.profile under DietPi (with MATE as the UI), it doesn't work.
I'm guessing that with DietPi/MATE, I need to add those lines to a different file.  Does anyone know which file I need to edit?
Rock64Pro and 4K resolution - by rrosenheim - 06-16-2019, 02:53 PM
RE: Rock64Pro and 4K resolution - by Luke - 06-16-2019, 04:53 PM
  New LCD Display for ROCK64Pro chilicon 0 2,507 03-10-2020, 02:05 PM
Last Post: chilicon
Question NextCloud with Rock64Pro aj64 2 5,718 01-14-2019, 06:22 AM
Last Post: aj64
