RockPro64 pcie Gpu
PC graphic cards have some x86 code that is called by the BIOS to early initialize the card so you can see text while booting. Of course this will not be available on non-x86 platforms. If the Xorg driver can initialize the card it may work, but you need it to be compiled for ARM (nouveau?). And you should make sure that the card is correctly detected. I could not use a SATA controller (LSI 9211-8i) until a hack named "pcie_rk_bus_scan_delay" was added to the kernel. You only need a riser/extender if you suspect that the Rockpro64 is not being able to supply enough current.
RockPro64 pcie Gpu - by Davidos - 05-28-2019, 02:57 AM
RE: RockPro64 pcie Gpu - by guannais - 06-09-2019, 02:09 PM
  Installing Wifi drive for the RockPro64 John45595 0 302 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 747 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 679 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,239 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 883 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,315 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,812 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,638 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,011 01-27-2023, 07:43 PM
Last Post: Spater
  PCIE interface power on too late Slark Xiao 0 1,006 11-29-2022, 11:56 PM
Last Post: Slark Xiao
