USB3 enough to power 2,5 external HDD?
(05-27-2019, 03:40 AM)Luke Wrote: huh. Interesting Smile So, from what you write, it does appear to be a power issue. I am not the most competent person to help determine why this is happening, so I suggest joining the chat and asking.
As for installing mainline here is the kenrel: https://github.com/ayufan-rock64/linux-m...l/releases
Just download, dpkg -i, and reboot.
With mainline kernel + stable ayufan stretch, none of the USB port work. On mrfixit's I cant install the mainline kernel because it says the architecture is different.
I'm beginning to think the power supply does not provide a stable output of 5V 3A. I ordered a multimeter to run some tests... Let's see then.
USB3 enough to power 2,5 external HDD? - by va88 - 05-25-2019, 01:59 PM
RE: USB3 enough to power 2,5 external HDD? - by va88 - 05-27-2019, 07:09 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,357 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 7,763 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 2,390 09-06-2022, 02:46 AM
Last Post: ju0n
  USB3 SATA ReleaseTheGeese 2 4,220 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 3,388 08-21-2020, 09:16 PM
Last Post: prog-amateur
  USB3 to SATA cable - Firmware Eule 0 2,968 03-03-2020, 01:31 PM
Last Post: Eule
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 5,608 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 3,944 06-23-2019, 05:01 PM
Last Post: Rocklobster
  How to check if my power supply is underperforming? va88 3 6,441 06-02-2019, 05:59 PM
Last Post: va88
