USB3 enough to power 2,5 external HDD?
Auyfan's stable bionic minimal image gives me this when I try to write on the drive. I'll try DietPi next.
[ 1290.527712] Buffer I/O error on device sdb1, logical block 34816
[ 1290.528427] Buffer I/O error on device sdb1, logical block 34817
[ 1290.529101] Buffer I/O error on device sdb1, logical block 34818
[ 1290.529779] Buffer I/O error on device sdb1, logical block 34819
[ 1290.530455] Buffer I/O error on device sdb1, logical block 34820
[ 1290.531116] Buffer I/O error on device sdb1, logical block 34821
[ 1290.535704] Buffer I/O error on device sdb1, logical block 34822
[ 1290.540151] Buffer I/O error on device sdb1, logical block 34823
[ 1290.544512] Buffer I/O error on device sdb1, logical block 34824
[ 1290.548791] Buffer I/O error on device sdb1, logical block 34825
[ 1290.554958] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 4198400 starting block 35584)
[ 1290.555516] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 4198400 starting block 35840)
[ 1290.557340] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 6295552 starting block 36096)
[ 1290.557892] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 6295552 starting block 36352)
[ 1290.559766] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 8388608 starting block 36608)
[ 1290.560308] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 8388608 starting block 36864)
[ 1290.563064] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 0 size 8388608 starting block 37120)
[ 1290.564834] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 8388608 size 3149824 starting block 37376)
[ 1290.565376] EXT4-fs warning (device sdb1): ext4_end_bio:330: I/O error -5 writing to inode 12 (offset 8388608 size 3149824 starting block 37632)
[ 1290.586305] JBD2: Detected IO errors while flushing file data on sdb1-8
[ 1290.586334] Aborting journal on device sdb1-8.
[ 1290.590635] EXT4-fs (sdb1): previous I/O error to superblock detected
[ 1290.590884] JBD2: Error -5 detected when updating journal superblock for sdb1-8.
[ 1290.591125] JBD2: Detected IO errors while flushing file data on sdb1-8
[ 1290.599521] EXT4-fs error (device sdb1): ext4_journal_check_start:56: Detected aborted journal
[ 1290.604178] EXT4-fs (sdb1): Remounting filesystem read-only
[ 1290.608543] EXT4-fs (sdb1): previous I/O error to superblock detected
[ 1290.625292] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[ 1290.625676] xhci-hcd xhci-hcd.9.auto: remove, state 4
[ 1290.625715] usb usb4: USB disconnect, device number 1
[ 1290.626780] xhci-hcd xhci-hcd.9.auto: USB bus 4 deregistered
[ 1290.627094] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1290.627355] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 1290.627557] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010
[ 1290.627600] xhci-hcd xhci-hcd.9.auto: irq 179, io mem 0xff600000
[ 1290.627813] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1290.627824] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1290.627831] usb usb4: Product: xHCI Host Controller
[ 1290.627838] usb usb4: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
[ 1290.627844] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 1290.628618] hub 4-0:1.0: USB hub found
[ 1290.628699] hub 4-0:1.0: 1 port detected
[ 1290.629214] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 1290.629505] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 1290.629630] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1290.629758] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 1290.629767] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1290.629774] usb usb5: Product: xHCI Host Controller
[ 1290.629781] usb usb5: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
[ 1290.629787] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 1290.630683] hub 5-0:1.0: USB hub found
[ 1290.630738] hub 5-0:1.0: 1 port detected
[ 1290.948125] usb 5-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 1290.960242] usb 5-1: New USB device found, idVendor=1058, idProduct=0748
[ 1290.960275] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1290.960298] usb 5-1: Product: My Passport 0748
[ 1290.960319] usb 5-1: Manufacturer: Western Digital
[ 1290.960340] usb 5-1: SerialNumber: 575844314539314E53564632
[ 1290.962826] usb-storage 5-1:1.0: USB Mass Storage device detected
[ 1290.966470] scsi host10: usb-storage 5-1:1.0
[ 1291.969311] scsi 10:0:0:0: Direct-Access     WD       My Passport 0748 1010 PQ: 0 ANSI: 6
[ 1291.970180] scsi 10:0:0:1: Enclosure         WD       SES Device       1010 PQ: 0 ANSI: 6
[ 1291.977437] sd 10:0:0:0: [sdc] Spinning up disk...
As you can see, it throws a bunch of I/O errors and the system assigns a new letter for the drive next.
USB3 enough to power 2,5 external HDD? - by va88 - 05-25-2019, 01:59 PM
RE: USB3 enough to power 2,5 external HDD? - by va88 - 05-25-2019, 04:24 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,362 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 7,787 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 2,390 09-06-2022, 02:46 AM
Last Post: ju0n
  USB3 SATA ReleaseTheGeese 2 4,226 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 3,400 08-21-2020, 09:16 PM
Last Post: prog-amateur
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 5,618 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 3,959 06-23-2019, 05:01 PM
Last Post: Rocklobster
  How to check if my power supply is underperforming? va88 3 6,455 06-02-2019, 05:59 PM
Last Post: va88
