First Manjaro Mainline build!
Installed Manjaro the other day and ran into an issue with the ethernet connection. Transfer rates came down to zero when submitting large packages. As a result I was not able to update the system or browse the internet. I ended up copying the rk3399-rockpro64.dtb device tree file from an armbian installation to my Manjaro installation. With that device tree file everything is fine and I have a fast ethernet connection. As Manjaro uses the mainline kernel, it seems as if there are some kernel mods around which haven't found their way into mainline yet (mr.fixit's kernel is working, too). Browsing the armbian forum, searching for rp64 related information, I found a thread where a maintainer described the cumbersome process of submitting patches to the mainline kernel.  So one can only wait until, hopefully,these patches will be applied to mainline.
First Manjaro Mainline build! - by Luke - 05-21-2019, 10:35 AM
RE: First Manjaro Mainline build! - by beard5849 - 07-04-2019, 12:28 AM
RE: First Manjaro Mainline build! - by pineadmin - 07-10-2019, 01:36 AM
RE: First Manjaro Mainline build! - by pineadmin - 07-11-2019, 01:01 AM
RE: First Manjaro Mainline build! - by mknawabi - 07-17-2019, 04:50 PM
RE: First Manjaro Mainline build! - by Luke - 07-17-2019, 05:42 PM
RE: First Manjaro Mainline build! - by Bullet64 - 05-03-2020, 02:35 AM
RE: First Manjaro Mainline build! - by nemster - 10-18-2020, 09:49 AM
RE: First Manjaro Mainline build! - by vfr400racer - 10-20-2020, 04:29 AM
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 150 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,281 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,391 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,630 04-23-2023, 01:32 PM
Last Post: diederik
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,025 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 1,648 12-31-2021, 12:51 AM
Last Post: publiclewdness
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 3,808 09-11-2021, 08:58 PM
Last Post: t4_4t
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 2,532 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  Headphone jack issues Manjaro Mangled 2 4,272 03-06-2021, 11:01 PM
Last Post: Mangled
Question Mainline Debian Buster on RockPro64 ? chrestomanci 36 54,531 02-14-2021, 02:37 PM
Last Post: foresto
